DANC
Banging my head against a SCCM brick wall !
My 1st post here and I hope you can help.
I have just setup SCCM 2007 SP2 and I am trying to perform a simple install and capture task. The PC starts booting WinPe and loads the SCCM splash screen (F8 is enabled, I get a IP and DNS is good). After about 2 mins my PC re-boots.
Looking at the smsts log I keep getting the following error:
<![LOG[Attempting to connect to \\DC1.MICROSOFT.LOCAL\SMSPKGE$\MS100003\]LOG]!><time="21:41:25.941+-60" date="10-29-2010" component="TSPxe" context="" type="1" thread="1452" file="resolvesource.cpp:2151">
<![LOG[Deleting any existing network connections to "\\DC1.MICROSOFT.LOCAL\*".]LOG]!><time="21:41:25.941+-60" date="10-29-2010" component="TSPxe" context="" type="0" thread="1452" file="tsconnection.cpp:407">
<![LOG[Attempting to connect to "\\DC1.MICROSOFT.LOCAL\SMSPKGE$\MS100003".]LOG]!><time="21:41:25.941+-60" date="10-29-2010" component="TSPxe" context="" type="0" thread="1452" file="tsconnection.cpp:501">
<![LOG[Retrying download...]LOG]!><time="21:41:25.956+-60" date="10-29-2010" component="TSPxe" context="" type="1" thread="1452" file="tsconnection.cpp:508">
<![LOG[Attempting to connect to "\\DC1.MICROSOFT.LOCAL\SMSPKGE$\MS100003".]LOG]!><time="21:41:28.967+-60" date="10-29-2010" component="TSPxe" context="" type="0" thread="1452" file="tsconnection.cpp:501">
<![LOG[Retrying download...]LOG]!><time="21:41:28.967+-60" date="10-29-2010" component="TSPxe" context="" type="1" thread="1452" file="tsconnection.cpp:508">
<![LOG[Attempting to connect to "\\DC1.MICROSOFT.LOCAL\SMSPKGE$\MS100003".]LOG]!><time="21:41:31.978+-60" date="10-29-2010" component="TSPxe" context="" type="0" thread="1452" file="tsconnection.cpp:501
If I do a net use I can connect to that share, so I know my permissions are ok. Help !!!
Dan
4 answers to this question
is it restaring before you select the TS or after ? there should be other information from the log since the info which you posted seems to no issue.
Thanks for the reply.
Its restarting before I selelct any task. The end of the log looks like this :
<![LOG[Failed to connect to "\\DC1.MICROSOFT.LOCAL\SMSPKGE$\MS100003" (67)]LOG]!><time="21:41:56.111+-60" date="10-29-2010" component="TSPxe" context="" type="3" thread="1452" file="tsconnection.cpp:517">
<![LOG[!slistSMBPaths.empty(), HRESULT=80040103 (e:\nts_sms_fre\sms\framework\tscore\resolvesource.cpp,2163)]LOG]!><time="21:41:56.111+-60" date="10-29-2010" component="TSPxe" context="" type="0" thread="1452" file="resolvesource.cpp:2163">
<![LOG[FALSE, HRESULT=80040103 (e:\nts_sms_fre\sms\framework\tscore\tspolicy.cpp,1635)]LOG]!><time="21:41:56.111+-60" date="10-29-2010" component="TSPxe" context="" type="0" thread="1452" file="tspolicy.cpp:1635">
<![LOG[Content location request for MS100003:1 failed. (Code 0x80040103)]LOG]!><time="21:41:56.111+-60" date="10-29-2010" component="TSPxe" context="" type="3" thread="1452" file="tspolicy.cpp:1635">
<![LOG[pTSPolicyManager->GetContentLocations( m_sPackageID, m_lSourceVersion, m_dwContentSourceFlags, slistContentLocations, slistHttpContentLocations, slistMulticastContentLocations, m_dwContentPackageFlags ), HRESULT=80040103 (e:\nts_sms_fre\sms\framework\tscore\tspolicy.cpp,2330)]LOG]!><time="21:41:56.111+-60" date="10-29-2010" component="TSPxe" context="" type="0" thread="1452" file="tspolicy.cpp:2330">
<![LOG[(*iTSReference)->Resolve( pTSPolicyManager, dwResolveFlags ), HRESULT=80040103 (e:\nts_sms_fre\sms\framework\tscore\tspolicy.cpp,2862)]LOG]!><time="21:41:56.111+-60" date="10-29-2010" component="TSPxe" context="" type="0" thread="1452" file="tspolicy.cpp:2862">
<![LOG[m_pSelectedTaskSequence->Resolve( m_pPolicyManager, TS::Policy::TaskSequence::ResolvePolicy | TS::Policy::TaskSequence::ResolveSource, fpCallbackProc, pv, hCancelEvent), HRESULT=80040103 (e:\nts_sms_fre\sms\client\tasksequence\tsmbootstrap\tsmediawizardcontrol.cpp,1208)]LOG]!><time="21:41:56.111+-60" date="10-29-2010" component="TSPxe" context="" type="0" thread="1452" file="tsmediawizardcontrol.cpp:1208">
<![LOG[Failed to resolve selected task sequence dependencies. Code(0x80040103)]LOG]!><time="21:41:56.111+-60" date="10-29-2010" component="TSPxe" context="" type="3" thread="1452" file="tsmediawizardcontrol.cpp:1208">
<![LOG[ResolveAndExecuteSelectedTaskSequence( 0, 0, 0 ), HRESULT=80040103 (e:\nts_sms_fre\sms\client\tasksequence\tsmbootstrap\tsmediawizardcontrol.cpp,2113)]LOG]!><time="21:41:56.111+-60" date="10-29-2010" component="TSPxe" context="" type="0" thread="1452" file="tsmediawizardcontrol.cpp:2113">
<![LOG[RunWizardForPXE(), HRESULT=80040103 (e:\nts_sms_fre\sms\client\tasksequence\tsmbootstrap\tsmediawizardcontrol.cpp,2402)]LOG]!><time="21:41:56.111+-60" date="10-29-2010" component="TSPxe" context="" type="0" thread="1452" file="tsmediawizardcontrol.cpp:2402">
<![LOG[oTSMediaWizardControl.Run( sMediaRoot, true, true ), HRESULT=80040103 (e:\nts_sms_fre\sms\client\tasksequence\tsmbootstrap\tsmbootstrap.cpp,937)]LOG]!><time="21:41:56.111+-60" date="10-29-2010" component="TSPxe" context="" type="0" thread="1452" file="tsmbootstrap.cpp:937">
<![LOG[Execute( eExecutionEnv, sConfigPath, sTSXMLFile, uBootCount, &uExitCode ), HRESULT=80040103 (e:\nts_sms_fre\sms\client\tasksequence\tsmbootstrap\tsmbootstrap.cpp,1106)]LOG]!><time="21:41:56.111+-60" date="10-29-2010" component="TSPxe" context="" type="0" thread="1452" file="tsmbootstrap.cpp:1106">
<![LOG[Exiting with return code 0x80040103]LOG]!><time="21:41:56.111+-60" date="10-29-2010" component="TSPxe" context="" type="1" thread="1452" file="tsmbootstrap.cpp:1118">
<![LOG[Execution complete.]LOG]!><time="21:41:56.111+-60" date="10-29-2010" component="TSBootShell" context="" type="1" thread="804" file="bootshell.cpp:624">
<![LOG[Finalizing logging from process 760]LOG]!><time="21:41:56.111+-60" date="10-29-2010" component="TSBootShell" context="" type="1" thread="804" file="tslogging.cpp:1736">
<![LOG[Finalizing logs to root of first available drive]LOG]!><time="21:41:56.111+-60" date="10-29-2010" component="TSBootShell" context="" type="1" thread="804" file="tslogging.cpp:1578">
<![LOG[LOGGING: Setting log directory to "D:\SMSTSLog".]LOG]!><time="21:41:56.142+-60" date="10-29-2010" component="TSBootShell" context="" type="1" thread="804" file="tslogging.cpp:1803">
check to ensure the packages which are used in Task sequence are distributed to DP,from the log,there are some packages which are not resolved by it.
You might created n number of packages but forgoten to distributed to DP's. there is script which posted by Michael to check if all the Task sequence dependencies are avilable in DP or not.
Thanks - that worked
