using vNext in a LAB - Part 8. Installing WSUS, Adding SLP and SUP roles
In Part 1. of this series we Installed vNext.
In Part 2., we then Configured vNext to use the New AD Site as a boundary and Configured Discovery Methods in vNext.
In Part 3, we installed the Reporting Point Role along with some additional roles and configured them.
In Part 4 we configured the client Agents and deployed the vNext Client.
In Part 5 we deployed an Application to All Users.
In Part 6 we added Windows Deployment Services, added the PSP role, added the Windows 7 Enterprise image, and updated our boot image for Deploying Windows 7.
In Part 7 we created our Build and Capture Task Sequence, enabled the Network Access Account, Advertised (Deployed) the Task Sequence, and created a new hyper-v virtual machine for capturing the wim on.
Step 1. Add the WSUS role to our vNext server.
On our vNext server startup Server Manager. Click on Roles and click on Add Roles.
click on Next at the wizard welcome page, and select Windows Server Update Services (WSUS) from the list, answer yes to the required role services
you'll get a note about Web Server IIS, click next and next again
Click Install when prompted and review your results when done.
At this point the WSUS role will be downloaded and then installed. Depending on your internet connection this could take some time.
after a while it will say Configuring and (hidden from view) will be the WSUS wizard, so click on the wizard to bring it forward
you'll now see the Welcome to the WSUS 3.0 SP2 wizard
click next to continue and accept the EULA
accept the local download defaults (store updates locally)
choose Use an Existing Database on this server
and it should say successfully connected to SQL Server Instance
accept the Use an existing Default website
click next at the summary, click Finish
followed by Cancel *you must cancel the Windows Server Update Services Configuration Wizard*
finally click on Close
Step 2. Add the SUP and SLP roles
We will now add the Server Locator Point and Software Update Point roles to our vNext server. In the Wunderbar, click on Administration, select Site Operations, Site Roles. Right click and choose Create Roles
click on browse and select our vNext server
select Server Locator Point and Software Update Point and click next
Accept the SLP defaults
enter your proxy settings here if you have any otherwise click next
select Use this server as the active software update point
leave the synchronisation source settings as they are
enable the schedule, the 7 day default is good enough
leave Classifications as they are
de-select all products (we will choose them later)
Note: No updates will appear in the vNext console until you select updates from the Products list, we will do this later.
make sure only English is selected
click next at the summary and review the confirmation
