Showing results for tags '2008 r2'.
Morning, I have the opportunity to upgrade my SCCM 2012 SP1 server base OS to Server 2012. In addition, I now have the capacity to spread the load of the SCCM server across multiple SCCM servers. But before I dive in, I would like to know a few things that do not seem to be well documented. Has anyone tried to Upgrade a Server 2008 R2 to a Server 2012, with said server being an SCCM 2012 server? What were Your results\impressions? Would it be better to setup new servers instead? I aim to spread the various SCCM functions over several machines (until now, 1 server has been doing ALL
- 3 replies
- migratesccm
- 2012
- (and 6 more)
Hello, I have a problem installing SCCM 2012 on the SQL 2008 R2 cluster. When it goes through the prerequisites, and I specify my SQL server, it connects fine, but when it comes to creating the database on the server it fails, saying that it can’t connect to the server. I tried a different approach and installed a local copy of SQL 2008 R2. SCCM installed fine. I moved the database to the SQL cluster, tried to re-point to use cluster and it failed again. Here is some log from the attempt to re-point to cluster: INFO: SQL Connection succeeded. Connection: clustername.domain MASTER, Type:
