Showing results for tags 'Offlice Servicing'.
Forums
  • Cloud
    • Azure
    • Microsoft Intune
    • Office 365
    • Windows 365
  • General Stuff
    • General Chat
    • Events
    • Site News
    • Official Forum Supporters
    • Windows News
    • Suggestion box
    • Jobs
    • How do I ?
    • SMS 2003
    • Configuration Manager 2007
    • Configuration Manager 2012
    • Packaging
    • scripting
    • Endpoint Protection
  • Windows Client
    • how do I ?
    • Windows 10
    • Windows 8
    • Windows 7
    • Windows Vista
    • Windows XP
    • windows screenshots
  • Windows Server
    • Windows Server General
    • Active Directory
    • Microsoft SQL Server
    • KMS
    • Windows Deployment Services
    • NAP
    • Failover Clustering
    • PKI
    • Hyper V
    • Exchange
    • IIS/apache/web server
    • System Center Orchestrator
    • Lync
    • Application Virtualization
    • Sharepoint
    • WSUS
Filter by number of...
Group
Website URL
Location
Interests
Found 1 result
  1. Hi Everyone, I have a strange issue that I'd like some help on please. I've used the build and capture task sequence to capture a wim image. I add this wim to my Operating System Images and then run through the Scheduled Updates wizard. This all looks to work fine and I can see in my image's directory a .bak of my image alongside the slightly larger originally named, now with updates included wim file. The properties of the imported image list all of the updates that I requested to be installed - so all looks good to me(?) It's at this point that I deploy the image to the distribution point. And here's the problem, the size of the image on the distribution point is the same as the .bak image version and when I use this in a deployment task sequence the updates are of course missing. Is there a step that I am missing somewhere? I have deleted the .bak image from the directory and re-uploaded the image to the DP but that hasn't made a difference. I can delete the image from the SCCM console and re-import it and that will be fine, although as SCCM will not list the installed updates under the 'installed updates' tab in the image properties - and this seems like extra work. Has anyone else had this issue? Many thanks
