Showing results for tags 'Reporting Point'.
Forums
  • Cloud
    • Azure
    • Microsoft Intune
    • Office 365
    • Windows 365
  • General Stuff
    • General Chat
    • Events
    • Site News
    • Official Forum Supporters
    • Windows News
    • Suggestion box
    • Jobs
    • How do I ?
    • SMS 2003
    • Configuration Manager 2007
    • Configuration Manager 2012
    • Packaging
    • scripting
    • Endpoint Protection
  • Windows Client
    • how do I ?
    • Windows 10
    • Windows 8
    • Windows 7
    • Windows Vista
    • Windows XP
    • windows screenshots
  • Windows Server
    • Windows Server General
    • Active Directory
    • Microsoft SQL Server
    • KMS
    • Windows Deployment Services
    • NAP
    • Failover Clustering
    • PKI
    • Hyper V
    • Exchange
    • IIS/apache/web server
    • System Center Orchestrator
    • Lync
    • Application Virtualization
    • Sharepoint
    • WSUS
Filter by number of...
Group
Website URL
Location
Interests
Found 2 results
  1. Following along in the documentation, I get to where I want to install the Reporting Services Point Role. Figure no big deal. In walking through the steps of role setup everything is great until I go to dropdown the selection for the Reporting Server Instance. It does not see the reporting server instance. In looking at the SQL server, I don't see reporting services listed in the Start Menu and I selected Reporting Services on the original install. I've even gone back into SQL setup to look and SQL setup shows it is installed. Anyone have an idea?
  2. Hi I have an issue with getting the reporting to work in SCCM 2007, over one week ago, the PXE Server and the reporting stopped working. Following the threads here I got the PXE working again, but I still have issues with the reporting part. When it opens a webpage it generates the following error (got a different error before, now i get this): HTTP Error 500.0 - Internal Server Error The page cannot be displayed because an internal server error has occurred. Detailed Error Information Module IsapiModule Notification ExecuteRequestHandler Handler ASPClassic Error Code 0x800700aa Requested URL http://Serversdress:80/SMSReporting_XXX/Report.asp?ReportId=125 Physical Path C:\inetpub\wwwroot\SMSReporting_XXX\Report.asp Logon Method Anonymous Logon User Anonymous This is what I have tride so far. 1. Remove reporting point 2. Remove IIS role 3. Remove Windows Process activation Service (Had issues reinstalling the IIS role) 4. Do a full reinstallation of .net framework 3.5 SP1, 4 Client profile and 4 Extended 5. Add the ISS role (yes ASP is installed on it) 6. Add the reporting point back SMSReportingInstall.log says the following: Begin Install CMDLINE=/s /m=C:\PROGRA~1\MIF083~1\bin\i386\rep.val /deinstall Error running smswwwroot.vbs script Begin Install CMDLINE=/s /m=C:\PROGRA~1\MIF083~1\bin\i386\rep.val Error running smswwwroot.vbs script Rsetup.log says the following: ========================================== Initialize variables. Deinstallation beginning IIS is installed. Start web services. Configuring Registry. Executing: ReportingInstall /s /m=C:\PROGRA~1\MIF083~1\bin\i386\rep.val /deinstall ReportingInstall.exe returned 0 Cannot remove the Reporting registry key - Still in use. Finished ========================================== Initialize variables. IIS is installed. Start web services. Configuring Registry. Executing: ReportingInstall /s /m=C:\PROGRA~1\MIF083~1\bin\i386\rep.val ReportingInstall.exe returned 0 Finished Im a bit fresh to SCCM (but have some experience) and have been banging my head against the wall now for a week. Any help would be appreciated.
