Showing results for tags 'Return Code 0x800f0803'.
When applying updates via schedule updates, they're all failing with ErrorCode 2096 / Return Code 0x800f0803 / Error Code -2146498512 I imported a stock Windows 7 Enterprise with SP1 (x64) WIM last night I performed scheduled updates which successfully applied 93 updates. This morning, I went through Scheduled Updates again, and it shows 71 updates need to be applied. I'm trying to apply those updates via Scheduled Updates but they're all failing with the same set of errors. I've checked the following but I'm still having trouble: Running SCCM 2012 R2 (5.0.7958.1000) DISM version is 6.3.9600.16384 There's enough disk space even with the WIM mounted (90+GB) NTFS permissions are fine for %windir%\temp and D:\ConfigMgr_OfflineImageServicing SCEP is installed:exclusions have been created for %windir%\temp, D:\ConfigMgr_OfflineImageServicing, both 32-bit and 64-bit dism.exe and dismhost.exe (among others: 1, 2) real-time protection is disabled No other AV installed No other third-party suites installed (e.g.: AV or Firewall) that interfere with files, processes etc. Checked state of 'Exclusive' & 'TotalSessionPhases' by loading the registry of the WIM (reg load HKLM\mykey D:\mount\windows\system32\config\software); Both were set to 0. I can upload the offline serving log in its entirety but its more of what I pasted above. My objective is to fully patch the WIM before I apply other updates offline (e.g.: KB277551-v2, KB2732673, KB2728738). This way I can begin test deployments with a fully patched WIM as of 'now' and create our reference image which will have Office 2010 installed and fully patched. From there, the WIM will be updated either quarterly (or monthly) via Schedule Updates, after we've performed our regression tests. I guess the question I should be asking is: What's the proper/correct process for getting a stock WIM (be it Windows 7, Server 2008 R2, Server 2012 etc) fully up to date? What does that process look like and what does the Task Sequence look like? Help!
- 3 replies
- ErrorCode 2096
- Return Code 0x800f0803
(and 1 more)
Tagged with:
