Showing results for tags 'bitlocker management'.
I run the script for creating a BitLocker portals. , I tried to access the portal but cannot connect it keeps prompting for the credential.
- 23 replies
Hi Niall, Hope you are doing great. I was following your tutorial on migrating from MBAM to SCCM Bitlocker, as i am working on a project for a customer for same. Tutorial: https://www.niallbrady.com/2019/11/13/want-to-learn-about-the-new-bitlocker-management-in-microsoft-endpoint-manager-configuration-manager/#comment-2150 Background: They are currently using SCCM version 2006, and wanted to migrate bitlocker from MBAM. They already have a PKI infrastructure (AD Certificate Service), with the SCCM client showing being in PKI mode (in the sccm client). I followed your steps to enable https mode (as they are in HTTP/HTTPS mode) and when i did that it broke the environment, and the clients (across 15 regions) stopped connecting, so I reverted back. My question to you is, i want to continue and finish the project, can i do so without changing SCCM to full https mode? Thanks in advance for taking the time out to reply and assist, as well as to the forum members
