Showing results for tags 'eswar koneti'.
Forums
  • Cloud
    • Azure
    • Microsoft Intune
    • Office 365
    • Windows 365
  • General Stuff
    • General Chat
    • Events
    • Site News
    • Official Forum Supporters
    • Windows News
    • Suggestion box
    • Jobs
    • How do I ?
    • SMS 2003
    • Configuration Manager 2007
    • Configuration Manager 2012
    • Packaging
    • scripting
    • Endpoint Protection
  • Windows Client
    • how do I ?
    • Windows 10
    • Windows 8
    • Windows 7
    • Windows Vista
    • Windows XP
    • windows screenshots
  • Windows Server
    • Windows Server General
    • Active Directory
    • Microsoft SQL Server
    • KMS
    • Windows Deployment Services
    • NAP
    • Failover Clustering
    • PKI
    • Hyper V
    • Exchange
    • IIS/apache/web server
    • System Center Orchestrator
    • Lync
    • Application Virtualization
    • Sharepoint
    • WSUS
Filter by number of...
Group
Website URL
Location
Interests
Found 3 results
  1. Hi, I am trying to capture Windows 7 PC Image(which contains OS+SWs like Adobe,MS Office and all other SW without Hardware Drivers)to push to multiple different Hardware PCs. I read few articles regarding Windows Image Capturing is it best practice to Capture OS+SW without driver installed in VM and then import it to Task Sequence and push to multiple physical Host Machines?? I have little doubts, please help me to clear. 1. Is it the best practice to deploy captured OS With Software importing from Virtual Machine or can capture fresh OS of host physical PC itself as in my case we have multiple brand PC with same software to install for all the PCs but different drivers? 2. I even read in few articles to Disable the option Execute Sysprep in Task Sequence instead to manually execute the SYSPREP option logging into Windows 7 PC and executing the command SYSPREP with following options System Cleanup Action--->Enter System Out of Box Experience OOBE Enabling Generalize Shutdown options-->Restart 3.What will be the problem if instead of running sysprep manually why shouldn't be configured in Task Sequence itself? 4.After running sysprep and launching the \\DeploymentShare$\Scripts\LiteTouch.vbs to capture the image into MDT+WDS Server, should I include this captured ISO image into WDS Server? as i didn't seen in any article to include this capture image into WDS Server.. Request to please help on these doubts to carry further.. Thanks in advance..
  2. Hi! Am new to SCCM environment am trying to deploy Windows 7 OS via SCCM 2007 OSD terminology. Below is my scenario(lab setup using oracle vbox- Extension pack been installed for PXE boot) Windows server 2008 acting as AD integrated DNS, DHCP, WDS and PXE Service Point all are co-hosted in same server(for lab practice). Also SCCM 2007 R2,SQL Server 2005 R2 & MDT 2010 are installed all in the same Virtual Machine. DHCP is working quite fine, i configured PXE service point, WDS role is installed but without configuring the WDS, services are not getting invoke.so configured WDS Server and configured the DCHP options 60,66,67 In WDS Server enabled(ticked) the options "Do not listen on port 67" & "Configure DHCP option 60 to PXEclient" executed the wds cmd "wdsutil /set-server /usedhcpports:no /dhcpoption60:yes" changed the registry key "HKLM\system\currentcontrolset\services\wdsserver\providers\wdspxe usedhcpports to (0)" At DHCP Server manually included the server options Server option "066" String Data is updated to "(IP of WDS Server eg:10.0.0.10)" "067 String Data (\smsboot\x86\wdsnbp.com)" "060 String Data (PXEClient)" Ref to this link https://heineborn.com/tech/setting-option-66-and-67-for-dhcp configured the Operating System Deployment--->Boot images--->Operating System Images--->Operating System Install packages--->Task sequence (Create Task sequence using MDT) Advertised the Task Sequence to All unknown computer. When i try to boot the client PC from PXE boot option, it ends with the following errors Press F12 for network service boot PXE-M0F:Exiting Intel PXE ROM FATAL: Could not read from the boot medium! System halted. Please help me out in resolving this issue. Thanks in advance.
  3. Hi!! Am new to SCCM environment, i managed to install sccm 2007 with sql server 2005 SP2 in windows server 2008 OS. I have an mixed environmental client of both the Windows xp, windows 7 and windows 8.1 OS I created new program to deploy software silently without user's interaction to the software, but the software didnt found installed and also its not showing in user's control panel, advertise program.. One more query is, do cmd required to be filled in command line section-->under -->new program creation??? what i believe is for most of the exe and for msi, cmd line will get vary for installation.. Can anyone pls help me out in installing the any exe or msi software silently without user interaction to the program?! your reply will be highly appreciable, as am performing a project in a small organization, am completely new to sccm environment, referring to google and few videos am learning the thing now... So pls reply back to go ahead the project.!!!
