Showing results for tags 'installing applications'.
Forums
  • Cloud
    • Azure
    • Microsoft Intune
    • Office 365
    • Windows 365
  • General Stuff
    • General Chat
    • Events
    • Site News
    • Official Forum Supporters
    • Windows News
    • Suggestion box
    • Jobs
    • How do I ?
    • SMS 2003
    • Configuration Manager 2007
    • Configuration Manager 2012
    • Packaging
    • scripting
    • Endpoint Protection
  • Windows Client
    • how do I ?
    • Windows 10
    • Windows 8
    • Windows 7
    • Windows Vista
    • Windows XP
    • windows screenshots
  • Windows Server
    • Windows Server General
    • Active Directory
    • Microsoft SQL Server
    • KMS
    • Windows Deployment Services
    • NAP
    • Failover Clustering
    • PKI
    • Hyper V
    • Exchange
    • IIS/apache/web server
    • System Center Orchestrator
    • Lync
    • Application Virtualization
    • Sharepoint
    • WSUS
Filter by number of...
Group
Website URL
Location
Interests
Found 1 result
  1. Hello Everyone, First i would like to say thank you for your great guide on SCCM 2012 RC2! It was very useful for my organization. Today we're installing new computer from a syspreped image that we have to each OS & Hardware (desktops & laptops), and deploying new machines took too many configurations after deploying the image, that's why i've looked for a better solution, and then i've heared about SCCM, and found your great website. I'm new to the SCCM system & concept. I've watched CBT nuggets's guides on SCCM 2007 but it's still not coverying 2012, but i've kind of understand the concept. I've installed the SCCM 2012 RC2 server on a VM running on VMware ESX server (win 2008 r2 sp1 ent), With a local SQL 2008 r2 sp1 cu4 (8GB ram & 2 vCpu's), i've got about 200 devices and about 150 users & groups. I've got a few questions: 1. What is the recommandation for hardware in my case? is 8GB ram is too much? 2. I've got 2 different domains in a diffrent forests, in this case i've installed SCCM only for Domain A, is there a way to manage Domain B from this server? or sould i install another server for Domain B? 3. I've got 2 WSUS servers for each domain, what exactly do i need to do and configure in order to integrate the WSUS & the SCCM server? is it recommanded? where can i find information about it? 4. When trying to run a Build and Deploy TS i'm getting the following error: "Capture image has failed with the error code 0x00000032" what can i do to fix it? i've tried removing the license key but it didn't help much, and i'm still getting the same error mesages, how can i know what exactly caused the problem? 5. When trying to run a deploy TS I'm getting the following error: "failed to run task sequence XXX this task sequence cannot be run because a package referenced by the task sequence could not be found" even that i've deployed the whole application & packages on the sccm DP server role, when running the deploy without the softwares it's running smoothly. 6. How to i install softwares that i don't have their MSI files? for example EXE files of VBS files that installing softwares with preconfigured license? Note: Installing SCCM server: I think it will be much much better if you could create a guide on installing SQL Server 2008 R2 with SP1 & CU4 Thank you very much i'll really appreciate your help!
