Showing results for tags 'sccm 1702'.
More search options
Forums
  • Cloud
    • Azure
    • Microsoft Intune
    • Office 365
  • General Stuff
    • General Chat
    • Events
    • Site News
    • Windows News
    • Suggestion box
    • Jobs
    • How do I ?
    • Official Forum Supporters
    • SMS 2003
    • Configuration Manager 2007
    • Configuration Manager 2012
    • Packaging
    • scripting
    • Endpoint Protection
  • Windows Client
    • how do I ?
    • Windows 10
    • Windows 8
    • Windows 7
    • Windows Vista
    • Windows XP
    • windows screenshots
  • Windows Server
    • Active Directory
    • Microsoft SQL Server
    • KMS
    • Windows Deployment Services
    • NAP
    • Failover Clustering
    • PKI
    • Windows Server 2008
    • Windows Server 2012
    • Windows Server 2016
    • Windows Server 2019
    • Hyper V
    • Exchange
    • IIS/apache/web server
    • System Center Orchestrator
    • Lync
    • Application Virtualization
    • Sharepoint
    • WSUS
Filter by number of...
Group
AIM
MSN
Website URL
ICQ
Yahoo
Jabber
Skype
Location
Interests
Found 11 results
  1. Two questions The 7zip and Firefox are applications, which I can easily add/change an icon. Is there a similar process or method to make the "programs" from Packages have icons? 2nd question - Some of my applications don't show icons in Add/Remove Programs, While this doesn't really cause any issues other than it is less aesthetically pleasing, I am curious has anyone else come across this, and if so, is there a fix?
  2. Good Morning, Following the instructions here, I've attempted to replicate this same process with installing Windows 10 1607 LTSB. It does not apply the custom menu I exported. The log file contain any notice of failures for the package applying. I am using the copyprofile method (that I created my reference image using), is this causing issues?
  3. We are running configuration Manager update to 1702 version however it fails on Database upgrade. We have SQL server 2014 SP2 (Standard) and trying to upgrade SCCM from 1610 version to 1702. Please advise if you are aware of any fix for the same. Could you please advise?
  4. CCM Client can not install updates. Configuration console--Monitoring--Deployments Updates Group show unkonwn Uploaded the logs and pictures. Thanks! WindowsUpdate.log UpdatesStore.log WUAHandler.log
  5. Hi Experts, We are currently implementing SCCM Current Branch 1702 afresh for one of our customers replacing BMC Marimba, and it was only a week back that we were informed about another existing installation of SCCM in one of the regions. They are using SCCM 2012 SP2.for managing patching for both server and desktop endpoints, with one Primary site and 8 distribution points. Now in our current implementation, we are looking to manage approximately 10000 endpoints and 1500 servers via a standalone Primary with additional management server and multiple secondaries in remote locations and distribution points in smaller branch offices. My question is how can we merge both these hierarchies and bring them up to the latest i.e. 1702 and then finally upgrade to 1706? Now, i understand that schema extenstion is a forest wide activity and since SCCM is already installed do I have to still extend the schema? Is there any change in attributes with current branch.
  6. Clients in secondary site showing only 2 actions, unable to get policy Primary Site working fine. Cas.log error CacheConfig::InitializeFromWmi - GetSWDistSiteSettings failed with 0x80004005. Default site settings will be used PolicyAgent.log "Skipping request for user policy assignments due to agent configuration for authority 'SMS:" CAS.log PolicyAgent.log
  7. Good morning, I am trying to understand supercedence of an application, and I have a few questions... 1. Will I need to have Multiple applications for Supercedence to work? (for example: Firefox 52, Firefox 53, Firefox 54) If so, then the application list looks "junky" as it would have multiple copies of the same files?? 2. Will utilizing supercedence take up more disk space? (I assume if I have to keep at least current version / old version? or will it auto delete it) 3. If there is a nice guide, could someone point me in the direction of it? Thanks
  8. Hello and thanks for taking the time to read and maybe help! My current setup consists of: Server 2012 R2, Sql 2012, and SCCM Current Branch (1606) about . I am replacing this all with: Server 2016, SQL 2016, and SCCM 1702. Yes i said "Replacing" not upgrading or migrating. I am trying to preform a complete Cut over to a new primary site. I want a clean slate. I have found all kinds of guides to migrate and upgrade, but nothing on steps to take to preform a complete cut over? My question is, once i have everything built (Installing Sccm 1702 as i type this) what steps should i take to eliminate my previous site and distribution point, and re-associate all my clients with my new site? As well as anything else i may be initially forgetting? Thanks again everyone!
  9. SCCM 1702 Server 2012 R2 Windows 10 Devices Windows Firewall Off on All Devices Hi all, Having some real issues installing the SCCM Client onto my physical windows 10 devices, one is a Surface pro 3 and the other Fujitsu hardware. When i push the client the process never starts and if i run the a manual installation (ccmsetup.exe /mp:SCCMSERVER /logon SMSSITECODE=MYSITECODE) the client does install but if not assigned to any MP and the button to 'Find Site' is greyed out so can not be configured manually? The strange thing is i have been able to install it via push on a Hyper V Windows 10 machine i newly created. Please help ccmsetup.log
  10. I've created an application to install Mozilla Firefox. What I am trying to do is be able to Install either the Rapid Release version or the Extended Support Release version based upon which version a computer already has installed. I created the application and two deployment types that use registry based detection for the default key with a version #. (54.0 for RR and 52.2.0 for ESR). How can I prevent one then the other from installing, or specify that only the matching one that the client has will get installed? (I attempted to do this, and it installed the ESR, then the RR version). Thanks!
  11. I am trying to add a CAS to a stand along primary server and I get to the point where it is asking for the Path to the SQL Server data file and the Path to the SQL Server Log file, but doesn't proceed any further. If the SQL server is remote, does it still use a local C:\... path, and would it be the path on the remote server or local...SQL is installed as a default instance on another server called xwz. Won't go past screen shot below.
