Showing results for tags 'sql express'.
Forums
  • Cloud
    • Azure
    • Microsoft Intune
    • Office 365
    • Windows 365
  • General Stuff
    • General Chat
    • Events
    • Site News
    • Official Forum Supporters
    • Windows News
    • Suggestion box
    • Jobs
    • How do I ?
    • SMS 2003
    • Configuration Manager 2007
    • Configuration Manager 2012
    • Packaging
    • scripting
    • Endpoint Protection
  • Windows Client
    • how do I ?
    • Windows 10
    • Windows 8
    • Windows 7
    • Windows Vista
    • Windows XP
    • windows screenshots
  • Windows Server
    • Windows Server General
    • Active Directory
    • Microsoft SQL Server
    • KMS
    • Windows Deployment Services
    • NAP
    • Failover Clustering
    • PKI
    • Hyper V
    • Exchange
    • IIS/apache/web server
    • System Center Orchestrator
    • Lync
    • Application Virtualization
    • Sharepoint
    • WSUS
Filter by number of...
Group
Website URL
Location
Interests
Found 2 results
  1. I'm planning to install a secondary site server in my SCCM 2012 SP1 hierarchy and wanted to know if I should install the SQL Express(which installs by default) or install a new instance of SQL server 2012 enterprise? My primary site server is currently running remotely on SQL Server 2012 SP1. Thanks, Paul
  2. Dear All, I would like to create one test lab for learning SCCM from scratch, My hardware details are as below Lenovo Thinkpad T520 Laptop Intel® Core™ i7-2640M 16 GB RAM 500 GB HDD 7200 RPM Windows 7 Professional 64 Bit I have successfully installed ESXi 5.0 and have installed vSphere Client. I have added 4 HDD into ESXi, each 120 GB with 12 GB of RAM Disk Servers Disk Clients Disk Linux Disk Apps I wanna have my lab setup as below 1) Windows 2008 r2 enterprise server as domain controller (vServer.domain.local) 1 GB RAM, 30 GB HDD with single partition 2) Windows 2008 r2 enterprise server as member for sccm (vSCCM.domain.local) 4 GB RAM 120 GB HDD with two partitions 30 GB as "C:\" and remaining as "D:\" Would like to install Primary stand alone site ( No CAS ) Please guide me : 1) What are need to be configured in the domain controller (vServer.domain.local) 2) What are need to be configured in the member server (vSCCM.domain.local) 3) iNstallation of SQL Express 2008 Edition 4) iNstallation of SCCM 2012 in the member server (vSCCM.domain.local) 5) Creating Task Sequence for capturing image from reference pcs ( VM Clients XP 32 Bit, Win 7 32 & 64 Bit ) 6) Creating Collections based on above three configs 7) Adding packages like Java, Flash, Office ... 8) Creating OSD, i) Advertised through network ii) iNitiated through boot media (CD) iii) Deployed in offline mode from USB. I believe all of the above points has been covered in "windows-noob", Please I would like to have all the links and your suggestions under one topic so that it will be easy to follow step-1,step-2 and so on ... Please add your valuable suggestions for me to have a very good Learn-Lab Thanks & Regards Jamal A M
