Showing results for tags 'upgrade fail'.
Forums
  • Cloud
    • Azure
    • Microsoft Intune
    • Office 365
    • Windows 365
  • General Stuff
    • General Chat
    • Events
    • Site News
    • Official Forum Supporters
    • Windows News
    • Suggestion box
    • Jobs
    • How do I ?
    • SMS 2003
    • Configuration Manager 2007
    • Configuration Manager 2012
    • Packaging
    • scripting
    • Endpoint Protection
  • Windows Client
    • how do I ?
    • Windows 10
    • Windows 8
    • Windows 7
    • Windows Vista
    • Windows XP
    • windows screenshots
  • Windows Server
    • Windows Server General
    • Active Directory
    • Microsoft SQL Server
    • KMS
    • Windows Deployment Services
    • NAP
    • Failover Clustering
    • PKI
    • Hyper V
    • Exchange
    • IIS/apache/web server
    • System Center Orchestrator
    • Lync
    • Application Virtualization
    • Sharepoint
    • WSUS
Filter by number of...
Group
Website URL
Location
Interests
Found 2 results
  1. I'm using the "upgrade operating system task sequence", using the full media for 1903 x64 Semi Annual Channel (formerly CBB I believe). My attempt is to go from 1607 LTSB to 1903 CBB. I have an OSDSetupAdditionalUpgradeOptions specified, as the entry for Product Key didn't seem to put the "/pkey" into the command line. From smsts.log on a box that was affected, this is the resulting command it is running. Shortly after it fails with the "unknown error 0x80004005", I check setupact.log and setuperr.log and it shows the the following errors: One thing that sticks out is "Selected install choice is not available". ![LOG[Command line of Windows Setup upgrade: '"C:\_SMSTaskSequence\Packages\LIB001F8\SETUP.EXE" /ImageIndex 3 /auto Upgrade /quiet /noreboot /postoobe "C:\Windows\SMSTSPostUpgrade\SetupComplete.cmd" /postrollback "C:\Windows\SMSTSPostUpgrade\SetupRollback.cmd" /DynamicUpdate Disable /compat IgnoreWarning /pkey NPPR9-FWDCX-D2C8J-H872K-2YT43']LOG]! If I manually run setup.exe /pkey NPPR9-FWDCX-D2C8J-H872K-2YT43 from the mounted ISO, it upgrades from 1607 LTSB to 1903 CBB just fine. Any suggestions?
  2. Hi, im trying to do an in place Upgrade from 1703 but it keeps failing due to I think the system display language being en-gb. I’ve tried creating a package and running set-culture en-us then rebooting the device but it doesn’t change. If I run the command manually it works. Thanks in advance.
