nodiaque
Problem with TS
Hello everyone,
I'm having a hard time with a package in a task sequence. Here's what's happening:
I run the task sequence without the package, everything work but when I activate it, it downloads it, then run it but failed.
If I try to run it manually, everything run fine. I tried recreating the package from scratch, didn't work. The package I'm trying to install is Intel Management Engine 9.5.24.
I've attached my smsts.log file, what we can see is that:
Installation failed with error (0x8007000e) InstallSoftware 2014-07-23 15:10:43 1812 (0x0714)
CompleteExecution processed InstallSoftware 2014-07-23 15:10:43 1240 (0x04D8)
Setting TSEnv variable 'SMSTSInstallSoftwareJobID_CM1002BD_CM1200A7_Installer'='' InstallSoftware 2014-07-23 15:10:43 1812 (0x0714)
GetExecRequestMgrInterface successful InstallSoftware 2014-07-23 15:10:43 1812 (0x0714)
Releasing job request, jobID='{B6962CDB-64FE-46C8-87B5-471FB40580AE}' InstallSoftware 2014-07-23 15:10:43 1812 (0x0714)
Releasing of Job Request successful InstallSoftware 2014-07-23 15:10:43 1812 (0x0714)
CompleteJob successful InstallSoftware 2014-07-23 15:10:43 1812 (0x0714)
ReleaseSource() for C:\_SMSTaskSequence\Packages\CM1002BD. InstallSoftware 2014-07-23 15:10:43 1812 (0x0714)
reference count 1 for the source C:\_SMSTaskSequence\Packages\CM1002BD before releasing InstallSoftware 2014-07-23 15:10:43 1812 (0x0714)
Released the resolved source C:\_SMSTaskSequence\Packages\CM1002BD InstallSoftware 2014-07-23 15:10:43 1812 (0x0714)
pInstall->Install(sPackageID, sProgramName), HRESULT=8007000e (e:\nts_sccm_release\sms\client\osdeployment\installsoftware\main.cpp,361) InstallSoftware 2014-07-23 15:10:43 1812 (0x0714)
Install Software failed, hr=0x8007000e InstallSoftware 2014-07-23 15:10:43 1812 (0x0714)
Process completed with exit code 2147942414 TSManager 2014-07-23 15:10:43 2004 (0x07D4)
!--------------------------------------------------------------------------------------------! TSManager 2014-07-23 15:10:43 2004 (0x07D4)
Failed to run the action: Intel Management Engine 9.5.24.1790 Rev. A.
Unknown error (Error: 8007000E; Source: Unknown) TSManager 2014-07-23 15:10:43 2004 (0x07D4)
smsts.log
hmmm, but that computer as quite enough memory (Specially for a 100 mb file). Disabling Intel MEI allow the task to succesfully run and install the remaining software/drivers. From what I've read, it means "file not found" but if I send the same package through the software center, it installed without any problem :(
