Hi we work no internet connection, so to upgrade Sccm 1702 to SCCM 1706, i had to download the 27GB  files required for the prereq. So i did that  and started the update..
It failed everytime on a file hash check - and failed on different files.
I downloaded them and copied them over 3 times, also logged in as a different admin user and tried but got the same error, so basically it's stuffed
anyone encountered the same problem and what they did to resolve it
this is short log with error  :
INFO: Adding Permission: IF OBJECT_ID('EN_SetEnrollmentError') IS NOT NULL GRANT EXECUTE ON [EN_SetEnrollmentError] TO [smsdbrole_EnrollSvr]    09/10/2017 10:16:19 AM    3364 (0x0D24)
ERROR: Failed to get the buffer size for LookupAccountName. Error = 1332    09/10/2017 10:16:20 AM    3364 (0x0D24)
WARNING : The content has been changed without increase the Version.    09/10/2017 10:17:00 AM    3364 (0x0D24)
INFO: Removing byte order marker after reading from file (F:\Program Files\Microsoft Configuration Manager\CMUStaging\0F11CAA4-7F7F-454B-96D6-75F427D015CE\SMSSetup\bin\x64\AndroidDeepLinkInstallerTechnology.xml)    09/10/2017 10:17:03 AM    3364 (0x0D24)
GetFileVersionInfoSizeW failed for file (\\?\F:\Program Files\Microsoft Configuration Manager\CMUStaging\0F11CAA4-7F7F-454B-96D6-75F427D015CE\SMSSetup\bin\x64\00000409\ADSite.resx)(0X80070714)    09/10/2017 10:18:34 AM    3364 (0x0D24)
GetFileVersionInfoSizeW failed for file (\\?\f:\program files\microsoft configuration manager\bin\x64\00000409\adsite.resx)(0X80070714)    09/10/2017 10:18:34 AM    3364 (0x0D24)
GetFileVersionInfoSizeW failed for file (\\?\F:\Program Files\Microsoft Configuration Manager\CMUStaging\0F11CAA4-7F7F-454B-96D6-75F427D015CE\SMSSetup\bin\x64\00000409\CPUSpeed.resx)(0X80070714)    09/10/2017 10:18:34 AM    3364 (0x0D24)
GetFileVersionInfoSizeW failed for file (\\?\f:\program files\microsoft configuration manager\bin\x64\00000409\cpuspeed.resx)(0X80070714)    09/10/2017 10:18:34 AM    3364 (0x0D24)
GetFileVersionInfoSizeW failed for file (\\?\F:\Program Files\Microsoft Configuration Manager\CMUStaging\0F11CAA4-7F7F-454B-96D6-75F427D015CE\SMSSetup\bin\x64\00000409\Device_FreePhoneMemory.resx)(0X80070714)    09/10/2017 10:18:34 AM    3364 (0x0D24)
GetFileVersionInfoSizeW failed for file (\\?\f:\program files\microsoft configuration manager\bin\x64\00000409\device_freephonememory.resx)(0X80070714)    09/10/2017 10:18:34 AM    3364 (0x0D24)
GetFileVersionInfoSizeW failed for file (\\?\F:\Program Files\Microsoft Configuration Manager\CMUStaging\0F11CAA4-7F7F-454B-96D6-75F427D015CE\SMSSetup\bin\x64\00000409\Device_MinOSVersion.resx)(0X80070714)    09/10/2017 10:18:34 AM    3364 (0x0D24)
GetFileVersionInfoSizeW failed for file (\\?\f:\program files\microsoft configuration manager\bin\x64\00000409\device_minosversion.resx)(0X80070714)    09/10/2017 10:18:34 AM    3364 (0x0D24)
GetFileVersionInfoSizeW failed for file (\\?\F:\Program Files\Microsoft Configuration Manager\CMUStaging\0F11CAA4-7F7F-454B-96D6-75F427D015CE\SMSSetup\bin\x64\00000409\Device_MinAPILevel.resx)(0X80070714)    09/10/2017 10:18:34 AM    3364 (0x0D24)
GetFileVersionInfoSizeW failed for file (\\?\f:\program files\microsoft configuration manager\bin\x64\00000409\device_minapilevel.resx)(0X80070714)    09/10/2017 10:18:34 AM    3364 (0x0D24)
GetFileVersionInfoSizeW failed for file (\\?\F:\Program Files\Microsoft Configuration Manager\CMUStaging\0F11CAA4-7F7F-454B-96D6-75F427D015CE\SMSSetup\bin\x64\00000409\Device_OwnershipDesktop.resx)(0X80070714)    09/10/2017 10:18:34 AM    3364 (0x0D24)
GetFileVersionInfoSizeW failed for file (\\?\f:\program files\microsoft configuration manager\bin\x64\00000409\device_ownershipdesktop.resx)(0X80070714)    09/10/2017 10:18:34 AM    3364 (0x0D24)
GetFileVersionInfoSizeW failed for file (\\?\F:\Program Files\Microsoft Configuration Manager\CMUStaging\0F11CAA4-7F7F-454B-96D6-75F427D015CE\SMSSetup\bin\x64\00000409\Device_OwnershipMobile.resx)(0X80070714)    09/10/2017 10:18:34 AM    3364 (0x0D24)
GetFileVersionInfoSizeW failed for file (\\?\f:\program files\microsoft configuration manager\bin\x64\00000409\device_ownershipmobile.resx)(0X80070714)    09/10/2017 10:18:34 AM    3364 (0x0D24)
And more 30 files
WARNING: File hash mismatch for F:\Program Files\Microsoft Configuration Manager\CMUStaging\0F11CAA4-7F7F-454B-96D6-75F427D015CE\SMSSetup\Client\x64\msrdcoob_amd64.exe    09/10/2017 10:18:35 AM    3364 (0x0D24)
WARNING: File hash mismatch for F:\Program Files\Microsoft Configuration Manager\CMUStaging\0F11CAA4-7F7F-454B-96D6-75F427D015CE\SMSSetup\Client\x64\wic_x64_enu.exe    09/10/2017 10:18:54 AM    3364 (0x0D24)
ERROR: File hash check failed: 0x80070002    09/10/2017 10:18:54 AM    3364 (0x0D24)
ERROR: VerifyExternalFile failed: 0x80070002    09/10/2017 10:18:54 AM    3364 (0x0D24)
ERROR: Failed to find valid source for required external file    09/10/2017 10:18:54 AM    3364 (0x0D24)
ERROR: Failed to find valid source for required file 'wic_x64_enu.exe'. Aborting setup.    09/10/2017 10:18:54 AM    3364 (0x0D24)
Setup has encountered fatal errors while performing file operations.    09/10/2017 10:18:54 AM    3364 (0x0D24)
Failed to install update files.    09/10/2017 10:18:54 AM    3364 (0x0D24)
Failed to apply update changes 0x80004005    09/10/2017 10:19:04 AM    3364 (0x0D24)
Mostly this error.
GetFileVersionInfoSizeW failed for file...... dozens of files, see examples below
GetFileVersionInfoSizeW failed for file (\\?\C:\Program Files\Microsoft Configuration Manager\CMUStaging\0F11CAA4-7F7F-454B-96D6-75F427D015CE\SMSSetup\DeviceClientDeployment\ClientTransfer\00000409\DeviceClient_WINCE7.0_X86.CAB)(0X80070714) CONFIGURATION_MANAGER_UPDATE 9/28/2017 12:36:29 PM 8524 (0x214C)
GetFileVersionInfoSizeW failed for file (\\?\c:\program files\microsoft configuration manager\deviceclientdeployment\clienttransfer\00000409\deviceclient_wince7.0_x86.cab)(0X80070714) CONFIGURATION_MANAGER_UPDATE 9/28/2017 12:36:29 PM 8524 (0x214C)
