I am wanting us a generated Config.xml does anyone have experience of using this in SCCM. I have seen three options on the forums but i am not sure which one actually works.
/config:config.xml (This doesn't seem to work,some posts say that it looks for the file in the windows folder)
/config:\\server\SMSPKGE$\CEN0007\config.xml (point directly to a DP)
/config:%_SMSTSCEN0007%x86\config.xml (point to a the USMT package)
If anyone has actually done this can you let me which option i should use.
Hello All,
thanks in advance
T
%_SMSTS<packageid>%
