Coenie
Report Builder 2.0 is not installed as a click-once application
I've come across a Report Builder issue, which is quite baffling.
I have installed Report builder 3 , and two in the meantime, and tried the fixes as below, switching between two and three respectively within registry, but no luck
I've also tried to launch configmgr as local administrator, and two domain admin accounts on two seperate domains, and still no luck, please advise.
http://social.techne...4e-329698a917f2
Thanks.
Coenie
Hello!
Did you change the value located in the registry here?
Computer\HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\ConfigMgr10\AdminUI\Reporting
Change the "ReportBuilderApplicationmanifestName" to just change the 2 in there to a 3, and it should work.
Good luck!
Edit, could you post the error you get in a print screen?
Thanks, UAC is disabled on a domain level, but I have also ran as administrator, and the changes stay in registry, and does not reset.
Any other advice would be appreciated.
