nhottinger
Can I run an inventory report to check pc's for a shortcut with a specific path?
We have changed a server that many shortcuts to the application point to. I've been asked to determine which pc's have the incorrect shortcut so we can fix them. Is there a way to setup an inventory report to check which pc's have this bad shortcut? Or can I only inventory pc's' with a specific shortcut name?
I don't see an option to enable SMS_Software, but I do have "Enable the Asset Intelligence Synchronization Point" checked. But no Inventoried software.
** Edit **
I didn't look deep enough in. I found the checkbox for SMS_InstalledSoftware. It is not currently checked. I will check that and run an update and see what I come up with.
