Remote Clients
Hey Everyone,
I am looking at deploying a standalone instance of system center for a small business. System Center will be managing less than 1000 clients, however many of the clients will be remote. Does system center have an option to deploy/centrally manage these remote machines outside of my network? If so, do I need to move to a hiarrchy deployment or can I still use a standalone instance with some sort of edge server?
Thanks in advance!
chubacca
Yes, it's possible to manage remote clients. However, you're going to need:
1) a PKI infrastructure (clients will communicate over HTTPS)
2) a firewall/TMG solution to allow remote access over the proper ports
3) the firewall/TMG can potentially be bypassed, if you install an internet management point in the DMZ
Check out this post, to see what you're getting into. I recently went through this process, and it's not easy. A Standalone Primary instance will work:
http://www.systemcenterdudes.com/?p=193
Thanks wilbywilson! Appreciate the link, hopefully I can get things up and running!
