Problem injecting updates in OS images
Hi Guys,
Hi Guys,
I have problems to inject updates into the image. It gives me the following error message
"Not all selected software updates are currently available on current site. Distribute the updates to the site first and then perform the operation""
Do you have any idea. How am I suppose to know which updates are missing? I created a package with ALL windows 7 updates, but still the same message.
There is no way to get the updates required as the lookup for updates does not include the same criterias as what it says it needs to update the images.
Best Regards,
Aldo
Sorry but basicaly i cannot even schedule the offline servicing so the log file will be empty
Ok. Are your updates downloaded to a software update group? Double check. They should be listed as "Downloaded - Yes"
