Application and package mapping questions.
I am looking for some help to finish up the package and application mapping deployment solution. I have tested that ZTIGATHER is hissing my DB and the stored Proc is running. what I need help with is placement and tasks in the task sequence.
I am running "Use toolkit package" then "Gather" in my "Capture User Files and Settings" group then "Install Package" task with a dynamic variable of "PACKAGES". I also have a "Install Applications" Task with a variable of "APPLICATION".
So far my questions are around the install packages and applications tasks and if I have set those tasks up correctly. The blogs about this on the web detail everything but the task sequence parts.
