Sign in to follow this
jzeller01
Deplyment WMI is NOT Ready
We pushed Endpoint out to our campus clients within the last month and all has been good. The SCEP client is being pushed through Client Settings.
We recently re-imaged a couple machines using OS deployment and would expect that SCCM would see them as a not having the SCEP client and go ahead and install it again. However, we are getting the following messages in the EnpointProtectionAgent.log file and they repeat every 25 minutes or so:
Service startup notification received	EndpointProtectionAgent	7/28/2014 1:25:33 PM	2572 (0x0A0C)
Endpoint is triggered by CCMTask Execute.	EndpointProtectionAgent	7/28/2014 1:25:33 PM	2456 (0x0998)
Deployment WMI is NOT ready.	EndpointProtectionAgent	7/28/2014 1:25:33 PM	2456 (0x0998)
From what I can gather SCCM still thinks the SCEP client is managed since it shows managed in the ConifgMan console, so this is causing it not to push the client again. Something is cached somewhere and is not letting the install to proceed. Any thoughts?
Hi JZeller01,
Can you maybe try the SCCM Client Utility on the endpoint that is having an issue? It will attempt to fix WMI, and repair some things.
Here's the link: http://gallery.technet.microsoft.com/SCCM-Client-Utility-WMI-ec270313
Let's start there and see what we can figure out. Let us know either way.
