Replace device, keep collections/deployments
Hi all,
I guess I am missing something, but I cannot find a way to do what I need to do: I want to replace the device of a user with a new one, but create the new machine with just the same software and setup like the old.
So, I want to replace "pc A" with "pc B" and want the SCCM to take all the deployments that are tagged to "pc A" and use them to build "pc B" (different names/MAC). Basically I want to give the user his usuall setup, just on a new hardware. Not the user account or the data, that is redirected anyway, only the software deployments. Like "Hey SCCM, look on A is Adobe Acrobat, put that on B as well".....
I thought I could use the "source computer" option in the "Import single Computer" wizard, but that seems to copy the accounts only.....
Thanks in advance.
BJ
