Suspend bitlocker PIN entry
SCCM 2012 SP1, I have it set to suspend bitlocker PIN entry when SCCM restarts system, like after a windows update, problem is after the restart (and the PIN entry has been suspended and resumed) when you log on you are greeted with another restart prompt...
Also I noticed that when sccm resumes bit-locker protectors on system volume, the sms agent host service stops. From event log
"Faulting application name: CcmExec.exe, version: 5.0.7804.1600,
Faulting module name: rebootcoord.dll, version: 5.0.7804.1000."
SCCM 2012 SP1 CU5
  • 7 months later...
