wmmayms
Problems rerunning chained programs
Hi guys
A coupple of days ago a colleuge told me that he was having problems rerunning chained advertisements with the rightclick tools in SCCM.
SCCM Right click tolls can be downloaded from here: http://myitforum.com/cs2/blogs/rhouchins/0424ConfigMgrTools.zip
This is the error msg that you get when trying to to a rerun on a chained advertisement.
By a chained advertisement i mean that the advertisement will run several programs in a chain. Example:
I though this was very strange since i know ive used rerun on chained programs in SMS so I started digging and here is what i found out:
SCCM rightclick tools use the ReRunAdv.wsf script for rerunning programs.
This script is located on the following path: "C:\WINDOWS\SCCMTools\ReRunAdv.wsf"
In the function called "SetRerunBehavior" beginning on row 143 we can see the root of the why the script is not working.
We will get errors if the following query get more then 1 result.
Set objScheds = objNMS.ExecQuery("select * from CCM_SoftwareDistribution where ADV_AdvertisementID = '" & strAdvID & "'" )
Because of the following row (161):
if (objScheds.Count <> 1) then
This basiclly means that if we get more or less then 1 row when running the query we will get an error code of "-3" when running this function.
So why do we get more then one result?
Well this is because we have a chained advertisement which means we will get one row for each program in the chain. This is how it look in wbemtest (namespace: "\\<COMPUTERNAME>\root\ccm\policy\machine\actualconfig" ) when running this query:
So what we can do to make the advertiemsent rerun is either to alter the WQL query or we could simply change row 163
FROM
SetRerunBehavior = -3
TO
SetRerunBehavior = 0
This will make the script able to process this function with exit code 0, which in turn will make the script complete without error.
Since it will be able to get past this step now:
' Then make sure the program can be rerun
ret = SetRerunBehavior(strMachine, strAdvID, strOldRerunBehavior, "RerunAlways")
If ret < 0 then
MsgBox "Unable to set RerunBehaviour. Program will not rerun.", vbCritical OR vbOKOnly, "Rerun Advertisement Error"
Wscript.Quit(ret)
Else
' wscript.echo "Successfully set RerunBehaviour from " & strOldRerunBehavior & " to RerunAlways."
End If
I have tested this in two enviroments now and it´s working great in booth. I will tell you if i find any buggs with this solution.
6 answers to this question
Note there are allso some rightclick tools for SMS that use the same rerun script as the SCCM Tools:
ReRunAdv.wsf
These will allso get the same error as mentioned above.
Rightclick Tools that use the following script seems to be able to rerun chained programs though
SMSSend.vbs
Note i havent tried this script on SCCM. But it work great on SMS.
But it gives me different error(using the default script) given below.is this due to the scheduleID not found in policies ?Looked into CCM instances but not find the advID.
Has the client run through the advertisement once?
Does the client still have the advertisement?
NO,It doesnt run and client doesnt have.This could be the reason probably why it gives the error.
For "rerun" to work the client still has to be in a collection that is tied to the specific advertisement that you want to rerun.
Also the advertisement has to have ran once on this client before you can perform a rerun.
