SCCM 2012 + MDT 2013 Update 2 - suspend problems
Hi everyone
I have enjoyed your guides and posts a lot for many years, thanks!
I have a problem with my setup with SCCM 2012 and MDT 2013 Update integraded, i can't get LTIsuspend to work correctly for Windows 10 Enterprise or Windows 8.1 Enterprise.
I have two issued but same problem.
1. a newly created MDT TS with the syspend task.
Here the VM enters the suspend state, but the TS has run through the cleanup step so i cant use the resume link, because the scripts/folders for MDT is not located on the VM.
This happens for Windwos 10 Enterprise and Windows 8.1 Enterprise.
2 a custom MDT TS with UID and the syspend task.
Here the VM Enters the Suspend state, but the Windows Wizard shows up and i have to setup Language settings, after they are setup, a wait for Windows Critical update shows, and the computer reboots. After the reboot the TS continue instead.
I dont know wich logfiles etc you need so please ask for them.
I hope you can help me :)
Thanks and best regards
