Using serviceui.exe with thininstaller
I have a task sequence that uses serviceUI.exe to run the progress bar for thininstaller. I have noticed that the sequence just seems to hang on running. however when I press the power button the sequence kicks back off and it runs properly showing the progress bar and finishes the install.
I have not been able to find out what is causing this issue.
Here is my task.
I noticed that if I click on the mouse a few times the progress bar shows up.
