SCCM 2012 distribution point not created
Configuration :
server01 : windows 2012 r2 + sccm 2012 r2 sp1
server02 : windows 2012 r2 + sql server 2012 sp3
Service SQL :
user service sql server = domain\user_service_sql (authorized to open session as service)
setspn -A MSSQLSvc/server01:1433 domain\user_service_sql
setspn -A MSSQLSvc/server01.domain:1433 domain\user_service_sql
domain\server01$ account is member of local group administrators on server01
domain\server02$ account is member of local group administrators on server01
domain\server01$ account is member of local group administrators on server02
domain\server02$ account is member of local group administrators on server02
Installation
All the systems prerequesite are OK (IIS and is component, WSUS, Powershell, dotnet, wfc ....)
C:\NO_SMS_ON_DRIVE.SMS
Installation SCCM 2012 OK
Installation SCCM SP2 OK
Installation IIS / SMS component seams to be OK (server01).
Eobjects are created in the "System Management"
Limites are discovered/created.
I create one boundary.
The domain devices and users are discovered and are listes in the sccm console.
All seams to be ok.
In the site hierarchy the distribution point role is listed/installed for the server01
But there is no "distribution point" available/visible =>
Administration / distribution point => no item found.
I uninstalled distribution point role, wait 30mn, Reboot
Reinstall Distribution role => wait 30 mn, same problem, no more distribution point.
Nothing is added in IIS server01, the folder "SMS_DP$" are not created => no file SMSdpprov.log
No error in the distrmgr.log
JUST ONE ERROR ON THE server01 /
WMI ERROR 10 :
Query SELECT * FROM __InstanceOperationEvent WHERE TargetInstance ISA "ccm_siteassignment"
Namespace //./root/ccm/Policy/Machine
Error 0x80041010
Is it the same problem .
Same the install of SQL and SCCM 3 times (server01/server02) => same result (with or without cu3 / sccm)...
Any Idea to resolve this problem for creation of the distribution point.
Thanks a lot.
