Help creating custom report
I'm new to SCCM and SQL and I'm trying to figure out how to create a custom report that will display Netbios Name, MAC Address, and Serial Tag for all systems. Can anyone help me out?
Hi
Hope this code will be helpful for you... :rolleyes:
SELECT
a.Hardware_ID0 as [MAC Address],
a.Netbios_Name0 as [system Name],
b.serialnumber0 as [system S/No]
FROM v_r_system a,
v_gs_operating_system b
WHERE a.ResourceID = b.ResourceID
Sreeni...
I'm getting Invalid column name 'serialnumber0' Any suggestions?
Hi
SELECT
FROM v_r_system a,
Sreeni...
HI
I hope , you are using SCCM. The code which i given is for querying the details in SMS 2003 DB. I am sorry for that.
OK .. Please modify the code like this and try.
SELECT
FROM v_r_system a,
v_gs_pc_bios b
Thanks,
Sreeni.. :rolleyes:
That was getting the report to run, and i appreciate that. i am looking for the mac address of the internal NIC however, and i'm not sure what the report is giving me. any suggestions on what to edit to get that? i appreciate all of your help.
HI
This code will give you the NIC details:
SELECT
a.resourceid as [Resource ID],
b.serialnumber0 as [system S/No],
c.macaddress0 as [NIC Address],
c.adaptertype0 as [Adapter Type],
c.description0 as [Description]
FROM v_r_system a,
v_gs_pc_bios b,
v_GS_NETWORK_ADAPTER c
WHERE a.ResourceID = b.ResourceID and b.resourceid= c.resourceid
Cheers,
Sreeni :rolleyes:
  • 2 months later...
HI
SELECT
FROM v_r_system a,
v_gs_pc_bios b,
Cheers,
Sreeni :rolleyes:
Please help me to create report of
list of software /PC wise
Hardware Inventory Like Toshiba Machines, HP machines etc
Software Updates report like
User name machine name Critical important optional
Coloumns
Regards
Shee
