Reinstall Outlook 2007 using the same package
I have a Office 2007 package created which will remove the existing Office 2003 and replace with Office 2007, however I have some PCs that already has Office 2007 installed but Outlook not configured properly. Is there a method to update Outlook with the configuration info by using the orignal Office 2007 package?
If not then I would like to know how can I use a Per-Install command to remove the existing Office 2007 and then install the new Office 2007.
