Remote Tools connection failed
As it says in the topic, I'm unable to remote control my client PCs using Start -> Remote Tools in the ConfigMgr console. I have narrowed it down to a firewall issue, and I made headway, but haven't had success yet. I know it is a firewall problem, because was able to connect when I disabled it. I re-enabled it and started poking holes, but haven't gotten through. I did manage to go from "Unable to contact host," to "Connection failed (0x8000ffff)."
Per the Windows TechNet entry Windows Firewall Settings for Configuration Manager Clients, I allowed the following:
  • TCP port 135 open to the admin subnet
  • TCP ports 2701-2702 open to IPs in my admin subnet
  • The program C:\Windows\SysWOW64\RCAgent.exe
  • Allowed Remote Desktop connections (via System Properties control panel)
I believe it was after opening port 135 that I started getting 0x8000ffff. Anyone know what I'm leaving out? Thanks.
are you able to check whether port 135 is open from admin's computer?
