SCSM 2010 SP1 DW Installation Issue
Hello everyone,
On my environment, I`m using a Windows Hyper-V Server 2008 SP1 with the following virtual machines:
- Domain Controller ( AD,DNS,DHCP,CA)
- Exchange 2010 SP1
- SCCM 2007 R2 SP2
- SCOM 2007 R2 ( SQL Server 2008 R2 Enterprise Ed. is also install on SCOM )
- SCSM 2010 SP1
I`m using Windows Server 2008 R2 SP1 for all virtual machines, and SQL Server 2008 R2.
As you already noticed, I`m trying to integrate all of them as you successfully did in your tutorials, but I have an issue with SCSM – Data Warehouse installation
Note: For the installation of all my servers in my environment I`m using Administrator as domain admin.
On the SCOM server I also have the SQL Server 2008 R2, as default instance ( I`m not using any named instances )
When I install SCCM 2007 aka ConfigMgr Server, I use a SPN for installing the server ( http://technet.microsoft.com/en-us/library/bb735885.aspx )
Everything works great with that !
Now..
Just to be clear, for SCSM I’m using the 2 servers scenario ( http://technet.microsoft.com/en-us/library/ff460945.aspx )
I`m also using separate service accounts for every component:
_svcSCSMService ( which is also a local administrator on both SCSM servers )
_svcSCSMWorkflow ( domain user )
_svcSCSMReporting ( domain user )
SCSMAdmins ( security group which includes the Administrator account as domain account )
On the first SCSM server, I install "Service Manager management server" component, everything went very well.
Now, on the second SCSM server, I continue installing " Service Manager data warehouse management server" and every time I receive the following error:
Configuring reporting - An error occurred while executing a custom action:_AssignDwAdminAsSsrsContentManagerOnRootFolder.1CA03A32_06E0
So from what I understand:
_AssignDwAdminAsSsrsContentManagerOnRootFolder.1CA03A32_06E0_4726_8E63_FEA4484D9D6F = Sets the reporting account as the Content Manager on the System Center folder in SQL Server Reporting Services.
I also found this:
http://technet.microsoft.com/en-us/library/ff461019.aspx
You will need the following permissions when installing the data warehouse management server:
• Local administrator on the computer that you run Setup on
• Local administrator on the computer that will host the data warehouse database if on a remote computer
• Logged-in user must be a domain account
• Content Manager role in SQL Server Reporting Services at the site level (root)
• Sysadmin SQL Server role on the SQL Server instance where the data warehouse database is being created
I don`t understand how to set content manager role in SQL SRS, I set SCSMAdmin as sysadmin as a new login in SQL, but when I tried to add SCSMAdmins group to my sql reports page - Site Settings – Security – New Role Assignment (http://msdn.microsoft.com/en-us/library/ms156034.aspx )
I receive this error :
This is my users lists in AD:
This is my SQL services accounts ( all are domain users )
This is my SQL Login list:
SCSMAdmin account in SQL is sysadmin.
Here are the Logs
Does anyone have any idea or a hint on how to solve this issue ?
Thank you,
Best Regards,
Bogdan.
Okay I finally figure it out, SCOM and SCSM can't share the default instance !
All I have to do was to create another named instance in SQL 2008 R2, after that follow the steps from here:
http://technet.microsoft.com/en-us/library/ff461215.aspx
and continue with the SCSM DW installation wizard, choose the new named instance instead of the default instance, it works !
I hope it helps the others too.
Regards.
