alederer
Error using sample Offline migration
3 answers to this question
USMT Exit code 26 (USMT_INIT_ERROR)
  1. Software malfunction or unknown exception - Check all loaded .xml files for errors, common error when using /I to load the Config.xml file. - Setup and Initialization
  2. Multiple Windows installations found - Listfiles.txt could not be created. Verify that the location you specified for the creation of this file is valid.
  3. Unable to find a valid Windows directory to proceed with requested offline operation \r\n\t - Verify that the offline input file is present and that it has valid entries. USMT could not find valid offline operating system. Verify your offline directory mapping.
