Reboot after Starting Network in SCCMPE
Hi All,
I'm trying to do an OSD however when the machine im trying to do the deployment on as soon as the PC boots into the WinPE and when it gets to Starting Network section it reboots the PC once that's complete's. It doesn't seem to be seeing either of my Task Sequences nor is it prompting me for a password.
Any ideas for what i can do to get this working??
Thanks,
Brendan Thompson
Hi Peter,
I could understand that if it didn't happen on every single machine i try including Hyper-V VM's. Could there be any other reasons for this occuring?
DNS & DHCP are both functioning. For the F8 do you mean press it once i've entered into the PE?
I just tried to do F8 put it would not bring up Command Prompt even though the option is enabled on the image, it's still rebooting. I also burnt the WIM file to a CD and booted into it however it still reboots in the same section.
