Application with 32bit or 64bit dependencies
In this example, I am having trouble deploying the SCCM Console (for IT use -- remote view). It has a dependency of dotNet 4.0 which comes in 64bit and 32bit flavors. I'd prefer to install this automatically as needed, and install the correct version for each operating system.
Before I dig into this deeper, is this the best way to accomplish this or should I seek to do this targeted for different collections or something else?
I assume the correct way of making sure would be to filter deployment by doing:
Deployment Types > Properties > Requirements to be for each and selecting the appropriate OS?
  • 2 weeks later...
I'll do a write up when I get a chance. I'd like to specify this for things like Java 32bit and 64bit and .Net. Funny how pre-reqs are sometimes the quirkiest things to install.
