Sign in to follow this
SystemFailure
HELP!
Is there a way to DECLINE all updates WITHOUT using the GUI it crashes saying the database is busy. problem is i selected more updates than my hard drive can hold and now it has no more room to hold anything.
my guess would be deleting the files in your WSUS download location manually (where all you synchronized updates information is stored). After that you should be able to run a synchronisation again and you can start all over ;)
Connect an external storage, copy the WSUS folder to the external storage and then delete the folder from actual drive. Have you selected all the product updates ?
