Help Performing OS Refresh on Workstations
Hello All & Niall -
I need help. This weekend, about 15 workstations are being swapped over from XP to Windows 7. A true upgrade will not be performed, but in theory a USMT profile captured, our Gold Image (Win7) applied, then USMT profile restored.
I've tried many different Task Sequences to accomplish this, but cannot get it to work correctly. The last thing I tried was a Refresh Task Sequence as well as a UDI one. Attached is the last TS I tried as well as a UDI script. Maybe I'm thinking too hard.
What would be the best way to accomplish this with SCCM 2012 / MDT 2012 Update 1?
Thanks!
UDIWizard_Config.xml
What is the problem that you're experiencing? Are you getting error messages? Need more specifics.
By the way, you've got a massive task sequence there, considering the relatively simple task at hand! I would recommend taking the time to engineer a task sequence from the ground up that has only the steps that you specifically need in it. This isn't something that is done overnight.
Cheers,
Trevor Sullivan
http://trevorsullivan.net
http://twitter.com/pcgeek86
