SCCM 2012 on failover cluster SQL 2008 R2
We have SQL 2008 R2 SP2 failover cluster with no cumulative updates and want to install sccm on it.
We try to run install and have to simple warnings. Next step just press Begin Install.
Is it SCCM 2012 fully support cluster? Can you recommend best approach for cluster?
Thank you
