SCCM 2012 Queries and Values
Quick question regarding queries - anyone know where I could find the Values associated with the different Attributes?
For example my current dilemma - am trying to query to see which clients have Forefront deployed and the DeploymentState has values 1-5. Which is "Managed"?
Thanks in advance
matt
btw - reason for this particular query is that an automated process was done to get the computers moved from one domain to another. The computer accounts were all pre-populated in an OU and they show in the collection. We were having failures on the endpoint install due to issues with removing the older forefront apps and need to know which need to be looked at manually. The ones that all show managed seem are okay and we would like to eliminate them via a query and off-line comparison with another data set.
Its a bit difficult at the moment as MS has not published the SQL DB schema for CM 12.
You will have to look for inbuilt reports to get it done.
