SCCM 2012 R2 - PXE & Unknown Computer Issues - Please Help
Hi all,
I've installed SCCM 2012 R2 and enabled PXE for the Unknown computer collection. This is what I want, and all unknown machines image fine. Brilliant!
There is a problem however
We have hundreds of non-domained joined thin client terminals (asus revo) which have BIOS set to boot to PXE first. When the users power on in the morning, they are booting into the task sequence image!! This is very bad :-(
I've done a network discovery scan which has found all the thin clients, so I can see all their names and mac addresses in the 'all systems' collection. I guess that even if sccm discovers them, they are still unknown?
This could be a deal breaker :-(
ok, I just realized that if my task sequence is changed from mandatory to available, unknown machines need to press F12 to PXE
I guess that's a good enough work around at the minute
SCCM should not be allowing your thin clients to pick up the TS if they have been discovered. Are you sure you have deployed the TS to the unknown computer collection?
