Showing results for tags 'SCSM Console error'.
Forums
  • Cloud
    • Azure
    • Microsoft Intune
    • Office 365
    • Windows 365
  • General Stuff
    • General Chat
    • Events
    • Site News
    • Official Forum Supporters
    • Windows News
    • Suggestion box
    • Jobs
    • How do I ?
    • SMS 2003
    • Configuration Manager 2007
    • Configuration Manager 2012
    • Packaging
    • scripting
    • Endpoint Protection
  • Windows Client
    • how do I ?
    • Windows 10
    • Windows 8
    • Windows 7
    • Windows Vista
    • Windows XP
    • windows screenshots
  • Windows Server
    • Windows Server General
    • Active Directory
    • Microsoft SQL Server
    • KMS
    • Windows Deployment Services
    • NAP
    • Failover Clustering
    • PKI
    • Hyper V
    • Exchange
    • IIS/apache/web server
    • System Center Orchestrator
    • Lync
    • Application Virtualization
    • Sharepoint
    • WSUS
Filter by number of...
Group
Website URL
Location
Interests
Found 1 result
  1. I'm trying to deploy SCSM console to a group of users in the service desk. I keep getting an error during the installation of the dependent applications. In order to install SCSM console there are 4 application requirements: .NET Framework 3.5 SP1 ADO.NET Data Services Update for .NET Framework 3.5 SP1 SQLSERVER2008_ASAMO10_x64.msi Reportviewer Our systems have the .net frame work 3.5 already So Here is a copy of the appEnforce.log Can someone tell me why this keeps failing? ++++++ App enforcement completed (6 seconds) for App DT "ADO.net Install_x64" [scopeId_E3596217-B1AD-4248-A6B3-52ACD97748FC/DeploymentType_acb0ca69-b93a-4d31-86ce-024a9e9aaeae], Revision: 1, User SID: ] ++++++ AppEnforce 6/12/2013 9:09:37 AM 5044 (0x13B4) +++ Starting Install enforcement for App DT "ADO.net Install_x64" ApplicationDeliveryType - ScopeId_E3596217-B1AD-4248-A6B3-52ACD97748FC/DeploymentType_acb0ca69-b93a-4d31-86ce-024a9e9aaeae, Revision - 1, ContentPath - C:\Windows\ccmcache\h, Execution Context - Any AppEnforce 6/12/2013 9:10:57 AM 4236 (0x108C) A user is logged on to the system. AppEnforce 6/12/2013 9:10:57 AM 4236 (0x108C) Performing detection of app deployment type ADO.net Install_x64(ScopeId_E3596217-B1AD-4248-A6B3-52ACD97748FC/DeploymentType_acb0ca69-b93a-4d31-86ce-024a9e9aaeae, revision 1) for system. AppEnforce 6/12/2013 9:10:57 AM 4236 (0x108C) +++ Application not discovered. [AppDT Id: ScopeId_E3596217-B1AD-4248-A6B3-52ACD97748FC/DeploymentType_acb0ca69-b93a-4d31-86ce-024a9e9aaeae, Revision: 1] AppEnforce 6/12/2013 9:10:57 AM 4236 (0x108C) App enforcement environment: Context: Machine Command line: wusa.exe Windows6.1-KB982307-x64.msu /quiet Allow user interaction: No UI mode: 0 User token: null Session Id: 1 Content path: C:\Windows\ccmcache\h Working directory: AppEnforce 6/12/2013 9:10:57 AM 4236 (0x108C) Prepared working directory: C:\Windows\ccmcache\h AppEnforce 6/12/2013 9:10:57 AM 4236 (0x108C) Found executable file wusa.exe with complete path C:\Windows\system32\wusa.exe AppEnforce 6/12/2013 9:10:57 AM 4236 (0x108C) Prepared command line: "C:\Windows\system32\wusa.exe" Windows6.1-KB982307-x64.msu /quiet AppEnforce 6/12/2013 9:10:57 AM 4236 (0x108C) Executing Command line: "C:\Windows\system32\wusa.exe" Windows6.1-KB982307-x64.msu /quiet with user context AppEnforce 6/12/2013 9:10:57 AM 4236 (0x108C) Working directory C:\Windows\ccmcache\h AppEnforce 6/12/2013 9:10:57 AM 4236 (0x108C) Post install behavior is BasedOnExitCode AppEnforce 6/12/2013 9:10:57 AM 4236 (0x108C) Waiting for process 5060 to finish. Timeout = 120 minutes. AppEnforce 6/12/2013 9:10:57 AM 4236 (0x108C) Process 5060 terminated with exitcode: 2149842967 AppEnforce 6/12/2013 9:10:59 AM 4236 (0x108C) Looking for exit code -2145124329 in exit codes table... AppEnforce 6/12/2013 9:10:59 AM 4236 (0x108C) Unmatched exit code (2149842967) is considered an execution failure. AppEnforce 6/12/2013 9:10:59 AM 4236 (0x108C) ++++++ App enforcement completed (1 seconds) for App DT "ADO.net Install_x64" [scopeId_E3596217-B1AD-4248-A6B3-52ACD97748FC/DeploymentType_acb0ca69-b93a-4d31-86ce-024a9e9aaeae], Revision: 1, User SID: ] ++++++ AppEnforce 6/12/2013 9:10:59 AM 4236 (0x108C)
