SCCM Package Errors
We currently have a strange error when trying to deploy operating systems from the task sequence.
We are told that Configuration manager could not find the client package on the distribution point.
Yet when I check the status of the item it is showing as on the distribution point. Any ideas?
I have already tried redistributing the package to the DP and removed the DP role altogether and re-added to see if the role was the problem.
Edit : We are using SCCM 2012 R2
have you set the task sequence to "access content directly from DP" then the you must use a custom made client installation package because the builtin is read-only. Is it for all clients? otherwise check your boundary and boundary groups as well.
Regards,
Jörgen
