Deploying IE and detecting it using SCCM 2012R2
So I'm trying to put IE11 in SCCM as an application available to install. My problem is detecting that it is installed because until the reboot happens, version numbers don't change as far as I can tell. I've looked in regedit and just using the exe. Does anyone have a solution to this so that it doesn't show the users that the installation failed?
