Issue with Pushing out IE 11
I've been trying to push out IE 11 for the last couple of days to a machine that was just imaged with Windows 7 x64, but when I remote into this client machine and click on the IE icon IE8 will launch. When I look at the Control Panel/Programs & Features/View installed updates I don't see IE 11 installed.
Here's what version SCCM is currently on:
SCCM R2 2012 SP1
http://prajwaldesai.com/deploy-internet-explorer-11-using-sccm-2012-r2/
I've downloaded and installed/configured the IEAK 11 Administration Kit
I've downloaded and extracted the IE11 updates per the instructions.
I've added all the cab files into the Custom Components per the instructions.
Made sure that all of these KB's are set to "Install before IE" per the instructions.
Then made sure that it was a "Completely Silent Installation" and "No restart" per the instructions
Then choose all the defaults, which then packaged IE 11 into the folder I told it to save that information. When you open the destination folder you will see the IE11 package. One of them is an app and other one is windows installer package (.msi).
I then moved the IE11 folder over to the SCCM server, and then created a new application for IE11 in SCCM. Then I created a new IE11 collection in SCCM. The Content Distribution is showing all green for IE (Successfully distributed content).
The Software Center on the test client machine shows that IE11 has been installed
Here's the log files from the AppEnforce.log
+++ Starting Install enforcement for App DT "Internet Explorer 11 - Windows Installer (*.msi file)" ApplicationDeliveryType - ScopeId_6D2672DC-CAB1-4CB2-881F-7DD0D66AEF4E/DeploymentType_17540884-af81-4746-9be2-d935bc3e9566, Revision - 1, ContentPath - C:\CACHE\ccmcache\3, Execution Context - System AppEnforce 8/12/2015 9:26:55 AM 2372 (0x0944)
A user is logged on to the system. AppEnforce 8/12/2015 9:26:55 AM 2372 (0x0944)
Performing detection of app deployment type Internet Explorer 11 - Windows Installer (*.msi file)(ScopeId_6D2672DC-CAB1-4CB2-881F-7DD0D66AEF4E/DeploymentType_17540884-af81-4746-9be2-d935bc3e9566, revision 1) for system. AppEnforce 8/12/2015 9:26:55 AM 2372 (0x0944)
+++ MSI application not discovered [MSI Product Code: {8430238B-4220-4F62-AAD2-B43FCE2958E0}, MSI Product version: ] AppEnforce 8/12/2015 9:26:55 AM 2372 (0x0944)
App enforcement environment:
Context: Machine
Command line: msiexec /i "IE11-Setup-Full.msi" /q
Allow user interaction: No
UI mode: 0
User token: null
Session Id: 4294967295
Content path: C:\CACHE\ccmcache\3
Working directory: AppEnforce 8/12/2015 9:26:55 AM 2372 (0x0944)
Prepared working directory: C:\CACHE\ccmcache\3 AppEnforce 8/12/2015 9:26:55 AM 2372 (0x0944)
Found executable file msiexec with complete path C:\WINDOWS\system32\msiexec.exe AppEnforce 8/12/2015 9:26:55 AM 2372 (0x0944)
Prepared command line: "C:\WINDOWS\system32\msiexec.exe" /i "IE11-Setup-Full.msi" /q /qn AppEnforce 8/12/2015 9:26:55 AM 2372 (0x0944)
Valid MSI Package path = C:\CACHE\ccmcache\3\IE11-Setup-Full.msi AppEnforce 8/12/2015 9:26:55 AM 2372 (0x0944)
Advertising MSI package [C:\CACHE\ccmcache\3\IE11-Setup-Full.msi] to the system. AppEnforce 8/12/2015 9:26:55 AM 2372 (0x0944)
Executing Command line: "C:\WINDOWS\system32\msiexec.exe" /i "IE11-Setup-Full.msi" /q /qn with system context AppEnforce 8/12/2015 9:26:58 AM 2372 (0x0944)
Working directory C:\CACHE\ccmcache\3 AppEnforce 8/12/2015 9:26:58 AM 2372 (0x0944)
Post install behavior is BasedOnExitCode AppEnforce 8/12/2015 9:27:00 AM 2372 (0x0944)
Waiting for process 3408 to finish. Timeout = 119 minutes. AppEnforce 8/12/2015 9:27:02 AM 2372 (0x0944)
Process 3408 terminated with exitcode: 0 AppEnforce 8/12/2015 9:30:26 AM 2372 (0x0944)
Looking for exit code 0 in exit codes table... AppEnforce 8/12/2015 9:30:26 AM 2372 (0x0944)
Matched exit code 0 to a Success entry in exit codes table. AppEnforce 8/12/2015 9:30:26 AM 2372 (0x0944)
Performing detection of app deployment type Internet Explorer 11 - Windows Installer (*.msi file)(ScopeId_6D2672DC-CAB1-4CB2-881F-7DD0D66AEF4E/DeploymentType_17540884-af81-4746-9be2-d935bc3e9566, revision 1) for system. AppEnforce 8/12/2015 9:30:26 AM 2372 (0x0944)
+++ Discovered MSI application [AppDT Id: ScopeId_6D2672DC-CAB1-4CB2-881F-7DD0D66AEF4E/DeploymentType_17540884-af81-4746-9be2-d935bc3e9566, Revision: 1, MSI Product code: {8430238B-4220-4F62-AAD2-B43FCE2958E0}, MSI Product version: ] AppEnforce 8/12/2015 9:30:26 AM 2372 (0x0944)
++++++ App enforcement completed (211 seconds) for App DT "Internet Explorer 11 - Windows Installer (*.msi file)" [scopeId_6D2672DC-CAB1-4CB2-881F-7DD0D66AEF4E/DeploymentType_17540884-af81-4746-9be2-d935bc3e9566], Revision: 1, User SID: ] ++++++ AppEnforce 8/12/2015 9:30:26 AM 2372 (0x0944)
I'm not sure why it's not installing, when the log file above says its installed correctly.
Thanks in advance,
Sothpaw
Could be your detection method that you configured considering it's stating that it is installed.
Make sure that the detection rule you use differs between ie8 and ie11, maybe try custom detection method as opposed msi product code.
BTW your deployed system has been rebooted after installation of application? The command line used above should reboot as a norestart command is not in the command but just to make sure.
Hi Rocket Man,
I actually redid the IEAK on a different computer, this time at the end of the IEAK setup, I selected after the install of IE to have the computer restart, and the computer is still showing that IE8 is installed and not IE11. I then moved the installer folder and files over to my SCCM server on the E drive. Then created an old school package and device collection, put the laptop test computer into that test collection and here's the exexmgr log files:
Policy arrived for parent package CCM00029 program Installs IE 11 execmgr 8/14/2015 3:31:33 PM 3852 (0x0F0C)
Raising client SDK event for class CCM_Program, instance CCM_Program.PackageID="CCM00029",ProgramID="Installs IE 11", actionType 6l, value NULL, user NULL, session 4294967295l, level 0l, verbosity 30l execmgr 8/14/2015 3:31:33 PM 3852 (0x0F0C)
Raising event:
[sMS_CodePage(437), SMS_LocaleID(1033)]
instance of SoftDistProgramOfferReceivedEvent
AdvertisementId = "CCM20018";
ClientID = "GUID:71b49525-5037-499e-bc83-45afd90d17e8";
DateTime = "20150814223133.969000+000";
MachineName = "TUK13LT021";
ProcessID = 708;
SiteCode = "CCM";
ThreadID = 3852;
Successfully created a content request handle {25A12052-A89E-4F95-A254-5665BBCEF2FC} for the package CCM00029 version 4 execmgr 8/14/2015 3:31:33 PM 744 (0x02E8)
Program Installs IE 11 change to state STATE_ADVANCED_DOWNLOAD content in progress execmgr 8/14/2015 3:31:33 PM 744 (0x02E8)
Execution Request for advert CCM20018 package CCM00029 program Installs IE 11 state change from NotExist to AdvancedDownload execmgr 8/14/2015 3:31:33 PM 744 (0x02E8)
Raising client SDK event for class CCM_Program, instance CCM_Program.PackageID="CCM00029",ProgramID="Installs IE 11", actionType 1l, value , user NULL, session 4294967295l, level 0l, verbosity 30l execmgr 8/14/2015 3:31:33 PM 744 (0x02E8)
Mandatory execution requested for program Installs IE 11 and advertisement CCM20018 execmgr 8/14/2015 3:31:34 PM 1112 (0x0458)
Creating mandatory request for advert CCM20018, program Installs IE 11, package CCM00029 execmgr 8/14/2015 3:31:34 PM 1112 (0x0458)
Raising event:
instance of SoftDistWaitingContentEvent
DateTime = "20150814223134.100000+000";
PackageName = "CCM00029";
PackageVersion = "4";
ProcessID = 708;
ProgramName = "Installs IE 11";
SiteCode = "CCM";
ThreadID = 1112;
Successfully raised SoftDistWaitingContentEvent event for program Installs IE 11 execmgr 8/14/2015 3:31:34 PM 1112 (0x0458)
Execution Request for advert CCM20018 package CCM00029 program Installs IE 11 state change from WaitingDependency to WaitingContent execmgr 8/14/2015 3:31:34 PM 1112 (0x0458)
Raising client SDK event for class CCM_Program, instance CCM_Program.PackageID="CCM00029",ProgramID="Installs IE 11", actionType 1l, value , user NULL, session 4294967295l, level 0l, verbosity 30l execmgr 8/14/2015 3:31:34 PM 1112 (0x0458)
Raising client SDK event for class CCM_Program, instance CCM_Program.PackageID="CCM00029",ProgramID="Installs IE 11", actionType 1l, value NULL, user NULL, session 4294967295l, level 0l, verbosity 30l execmgr 8/14/2015 3:31:34 PM 2516 (0x09D4)
Raising client SDK event for class CCM_Program, instance CCM_Program.PackageID="CCM00029",ProgramID="Installs IE 11", actionType 1l, value NULL, user NULL, session 4294967295l, level 0l, verbosity 30l execmgr 8/14/2015 3:31:34 PM 1844 (0x0734)
Raising client SDK event for class CCM_Program, instance CCM_Program.PackageID="CCM00029",ProgramID="Installs IE 11", actionType 1l, value NULL, user NULL, session 4294967295l, level 0l, verbosity 30l execmgr 8/14/2015 3:31:34 PM 744 (0x02E8)
Raising client SDK event for class CCM_Program, instance CCM_Program.PackageID="CCM00029",ProgramID="Installs IE 11", actionType 1l, value NULL, user NULL, session 4294967295l, level 0l, verbosity 30l execmgr 8/14/2015 3:31:34 PM 3796 (0x0ED4)
Raising client SDK event for class CCM_Program, instance CCM_Program.PackageID="CCM00029",ProgramID="Installs IE 11", actionType 1l, value NULL, user NULL, session 4294967295l, level 0l, verbosity 30l execmgr 8/14/2015 3:31:48 PM 744 (0x02E8)
Raising client SDK event for class CCM_Program, instance CCM_Program.PackageID="CCM00029",ProgramID="Installs IE 11", actionType 1l, value NULL, user NULL, session 4294967295l, level 0l, verbosity 30l execmgr 8/14/2015 3:32:03 PM 3796 (0x0ED4)
Raising client SDK event for class CCM_Program, instance CCM_Program.PackageID="CCM00029",ProgramID="Installs IE 11", actionType 1l, value NULL, user NULL, session 4294967295l, level 0l, verbosity 30l execmgr 8/14/2015 3:32:18 PM 744 (0x02E8)
Raising client SDK event for class CCM_Program, instance CCM_Program.PackageID="CCM00029",ProgramID="Installs IE 11", actionType 1l, value NULL, user NULL, session 4294967295l, level 0l, verbosity 30l execmgr 8/14/2015 3:32:34 PM 1844 (0x0734)
Raising client SDK event for class CCM_Program, instance CCM_Program.PackageID="CCM00029",ProgramID="Installs IE 11", actionType 1l, value NULL, user NULL, session 4294967295l, level 0l, verbosity 30l execmgr 8/14/2015 3:32:49 PM 744 (0x02E8)
Raising client SDK event for class CCM_Program, instance CCM_Program.PackageID="CCM00029",ProgramID="Installs IE 11", actionType 1l, value NULL, user NULL, session 4294967295l, level 0l, verbosity 30l execmgr 8/14/2015 3:33:04 PM 2672 (0x0A70)
Raising client SDK event for class CCM_Program, instance CCM_Program.PackageID="CCM00029",ProgramID="Installs IE 11", actionType 1l, value NULL, user NULL, session 4294967295l, level 0l, verbosity 30l execmgr 8/14/2015 3:33:19 PM 3796 (0x0ED4)
Raising client SDK event for class CCM_Program, instance CCM_Program.PackageID="CCM00029",ProgramID="Installs IE 11", actionType 1l, value NULL, user NULL, session 4294967295l, level 0l, verbosity 30l execmgr 8/14/2015 3:33:34 PM 744 (0x02E8)
Raising client SDK event for class CCM_Program, instance CCM_Program.PackageID="CCM00029",ProgramID="Installs IE 11", actionType 1l, value NULL, user NULL, session 4294967295l, level 0l, verbosity 30l execmgr 8/14/2015 3:33:49 PM 744 (0x02E8)
Raising client SDK event for class CCM_Program, instance CCM_Program.PackageID="CCM00029",ProgramID="Installs IE 11", actionType 1l, value NULL, user NULL, session 4294967295l, level 0l, verbosity 30l execmgr 8/14/2015 3:34:05 PM 3796 (0x0ED4)
Raising client SDK event for class CCM_Program, instance CCM_Program.PackageID="CCM00029",ProgramID="Installs IE 11", actionType 1l, value NULL, user NULL, session 4294967295l, level 0l, verbosity 30l execmgr 8/14/2015 3:34:20 PM 3320 (0x0CF8)
Raising client SDK event for class CCM_Program, instance CCM_Program.PackageID="CCM00029",ProgramID="Installs IE 11", actionType 1l, value NULL, user NULL, session 4294967295l, level 0l, verbosity 30l execmgr 8/14/2015 3:34:35 PM 3320 (0x0CF8)
Raising client SDK event for class CCM_Program, instance CCM_Program.PackageID="CCM00029",ProgramID="Installs IE 11", actionType 1l, value NULL, user NULL, session 4294967295l, level 0l, verbosity 30l execmgr 8/14/2015 3:34:50 PM 3320 (0x0CF8)
Raising client SDK event for class CCM_Program, instance CCM_Program.PackageID="CCM00029",ProgramID="Installs IE 11", actionType 1l, value NULL, user NULL, session 4294967295l, level 0l, verbosity 30l execmgr 8/14/2015 3:35:05 PM 3796 (0x0ED4)
Raising client SDK event for class CCM_Program, instance CCM_Program.PackageID="CCM00029",ProgramID="Installs IE 11", actionType 1l, value NULL, user NULL, session 4294967295l, level 0l, verbosity 30l execmgr 8/14/2015 3:35:20 PM 3796 (0x0ED4)
Raising client SDK event for class CCM_Program, instance CCM_Program.PackageID="CCM00029",ProgramID="Installs IE 11", actionType 1l, value NULL, user NULL, session 4294967295l, level 0l, verbosity 30l execmgr 8/14/2015 3:35:35 PM 744 (0x02E8)
Raising client SDK event for class CCM_Program, instance CCM_Program.PackageID="CCM00029",ProgramID="Installs IE 11", actionType 1l, value NULL, user NULL, session 4294967295l, level 0l, verbosity 30l execmgr 8/14/2015 3:35:50 PM 744 (0x02E8)
Raising client SDK event for class CCM_Program, instance CCM_Program.PackageID="CCM00029",ProgramID="Installs IE 11", actionType 1l, value NULL, user NULL, session 4294967295l, level 0l, verbosity 30l execmgr 8/14/2015 3:36:06 PM 1676 (0x068C)
Raising client SDK event for class CCM_Program, instance CCM_Program.PackageID="CCM00029",ProgramID="Installs IE 11", actionType 1l, value NULL, user NULL, session 4294967295l, level 0l, verbosity 30l execmgr 8/14/2015 3:36:21 PM 744 (0x02E8)
Processing [{25A12052-A89E-4F95-A254-5665BBCEF2FC}, 0]: OnContentAvailable execmgr 8/14/2015 3:36:29 PM 1676 (0x068C)
[{25A12052-A89E-4F95-A254-5665BBCEF2FC}]: Content Version 4 is available for advert CCM20018, pkg: CCM00029, program Installs IE 11. execmgr 8/14/2015 3:36:29 PM 1676 (0x068C)
An existing MTC token was not supplied, using ExecutionRequest's Id as MTC token and this execution request is the owner of resultant MTC task. execmgr 8/14/2015 3:36:29 PM 1676 (0x068C)
Request a MTC task for execution request of package CCM00029, program Installs IE 11 with request id: {F337C343-8DFC-419E-9128-F4B247284A4F} execmgr 8/14/2015 3:36:29 PM 1676 (0x068C)
Execution Request for advert CCM20018 package CCM00029 program Installs IE 11 state change from WaitingContent to Ready execmgr 8/14/2015 3:36:30 PM 1676 (0x068C)
MTC task with id {F337C343-8DFC-419E-9128-F4B247284A4F}, changed state from 0 to 4 execmgr 8/14/2015 3:36:30 PM 2780 (0x0ADC)
Raising client SDK event for class CCM_Program, instance CCM_Program.PackageID="CCM00029",ProgramID="Installs IE 11", actionType 1l, value , user NULL, session 4294967295l, level 0l, verbosity 30l execmgr 8/14/2015 3:36:30 PM 1676 (0x068C)
Processing [{25A12052-A89E-4F95-A254-5665BBCEF2FC}, 0]: RemoveNotification execmgr 8/14/2015 3:36:30 PM 1676 (0x068C)
MTC signaled SWD execution request with program id: Installs IE 11, package id: CCM00029 for execution. execmgr 8/14/2015 3:36:30 PM 2780 (0x0ADC)
Sending ack to MTC for task with id: {F337C343-8DFC-419E-9128-F4B247284A4F} execmgr 8/14/2015 3:36:30 PM 2780 (0x0ADC)
Executing program msiexec /i "IE11-Setup-Full.msi" /q in Admin context execmgr 8/14/2015 3:36:30 PM 2780 (0x0ADC)
Execution Request for advert CCM20018 package CCM00029 program Installs IE 11 state change from Ready to NotifyExecution execmgr 8/14/2015 3:36:30 PM 2780 (0x0ADC)
Raising client SDK event for class CCM_Program, instance CCM_Program.PackageID="CCM00029",ProgramID="Installs IE 11", actionType 1l, value , user NULL, session 4294967295l, level 0l, verbosity 30l execmgr 8/14/2015 3:36:30 PM 2780 (0x0ADC)
Checking content location C:\CACHE\ccmcache\1 for use execmgr 8/14/2015 3:36:30 PM 2780 (0x0ADC)
Successfully selected content location C:\CACHE\ccmcache\1 execmgr 8/14/2015 3:36:30 PM 2780 (0x0ADC)
Executing program as a MSI script execmgr 8/14/2015 3:36:30 PM 2780 (0x0ADC)
Valid MSI Package path = C:\CACHE\ccmcache\1\IE11-Setup-Full.msi execmgr 8/14/2015 3:36:30 PM 2780 (0x0ADC)
Found executable file msiexec with complete path C:\WINDOWS\system32\msiexec.exe execmgr 8/14/2015 3:36:30 PM 2780 (0x0ADC)
Successfully prepared command line "C:\WINDOWS\system32\msiexec.exe" /i "IE11-Setup-Full.msi" /q execmgr 8/14/2015 3:36:30 PM 2780 (0x0ADC)
Current MSI script is an installation script execmgr 8/14/2015 3:36:30 PM 2780 (0x0ADC)
Advertising MSI package C:\CACHE\ccmcache\1\IE11-Setup-Full.msi to user execmgr 8/14/2015 3:36:30 PM 2780 (0x0ADC)
Command line = "C:\WINDOWS\system32\msiexec.exe" /i "IE11-Setup-Full.msi" /q, Working Directory = C:\CACHE\ccmcache\1\ execmgr 8/14/2015 3:36:30 PM 2780 (0x0ADC)
Running "C:\WINDOWS\system32\msiexec.exe" /i "IE11-Setup-Full.msi" /q with 32bitLauncher execmgr 8/14/2015 3:36:30 PM 2780 (0x0ADC)
Created Process for the passed command line execmgr 8/14/2015 3:36:30 PM 2780 (0x0ADC)
Raising event:
instance of SoftDistProgramStartedEvent
CommandLine = "\"C:\\WINDOWS\\system32\\msiexec.exe\" /i \"IE11-Setup-Full.msi\" /q";
DateTime = "20150814223630.647000+000";
ProcessID = 708;
SiteCode = "CCM";
ThreadID = 2780;
UserContext = "NT AUTHORITY\\SYSTEM";
WorkingDirectory = "C:\\CACHE\\ccmcache\\1\\";
Raised Program Started Event for Ad:CCM20018, Package:CCM00029, Program: Installs IE 11 execmgr 8/14/2015 3:36:30 PM 2780 (0x0ADC)
Raising client SDK event for class CCM_Program, instance CCM_Program.PackageID="CCM00029",ProgramID="Installs IE 11", actionType 1l, value NULL, user NULL, session 4294967295l, level 0l, verbosity 30l execmgr 8/14/2015 3:36:30 PM 2780 (0x0ADC)
MTC task with id {F337C343-8DFC-419E-9128-F4B247284A4F}, changed state from 4 to 5 execmgr 8/14/2015 3:36:30 PM 2780 (0x0ADC)
Program exit code 0 execmgr 8/14/2015 3:39:48 PM 2516 (0x09D4)
Looking for MIF file to get program status execmgr 8/14/2015 3:39:48 PM 2516 (0x09D4)
Script for Package:CCM00029, Program: Installs IE 11 succeeded with exit code 0 execmgr 8/14/2015 3:39:48 PM 2516 (0x09D4)
Raising event:
instance of SoftDistProgramCompletedSuccessfullyEvent
DateTime = "20150814223948.491000+000";
ProcessID = 708;
SiteCode = "CCM";
ThreadID = 2516;
Raised Program Success Event for Ad:CCM20018, Package:CCM00029, Program: Installs IE 11 execmgr 8/14/2015 3:39:48 PM 2516 (0x09D4)
Execution is complete for program Installs IE 11. The exit code is 0, the execution status is Success execmgr 8/14/2015 3:39:48 PM 1844 (0x0734)
that is strange...no errors...must be a problem with the ieak then.
Can you just for testing install ie9 or 10 manually on system and then re-advertise the ie11 application again and see if it installs.
You can also create an application from the .exe also, but you will need to fill in the extra stuff like detection method, install params etc... this will probably work better, and looking at the blog link you posted in your initial post it seems a lot of users are having the same issue as your self.
  • 5 weeks later...
I created an IEAK 11 for Internet Explorer 11 with the instruction on this link but the only change I made is the to prompt for a reboot.
Basically, I want my deployment to prompt or ask a reboot at the end of the installation.
What's happening is the push gets installed completely silent. You'll only find out after you reboot your computer manually.
What would be the best control of reboot prompt on IEAK or The deployment in SCCM?
Any Help would be Appreciated..Thank you
  • 4 months later...
@thenoid
I went through that same blog and never got it to work either. Had MS on the phone with me for 5 hours and they couldn't even tell me why it was failing. Then they sent me this link:
https://www.systemcenterdudes.com/upgrade-to-internet-explorer-11-with-sccm/
Created the 2 packages and then the TS. Deployed it to a small collection of computers and it worked unbelievably well! Total joy right? No. Deployed it again to another small collection and it worked on about half the machines and then didn't work on any collection I deployed to after that. It would install the prereqs, but not IE11. I've put several hundred hours in to trying to get this to work and it won't. I could have probably had our 1000 machine upgraded manually by now. Bad news is that nobody ever seem to be able to help with this stuff....not even MS themselves!!!
Good luck
