Issue with imaging
Having an issue with one of our DP's. It will pxe boot and get to the loading files screen, the progress bar hangs loading the boot.wim. Will sit there for hours and never get to the next step.. I have this same boot.wim on 3 other DP's and no issues with it. Any ideas?
Things I have done:
Removed the image
removed pxe
rebooted numerous times
enabled pxe
distribute the boot.wim back to the DP.
Nothing works.
2012 R2 SP1 CU3
Try to remove PXE role, Uninstall WDS, Remove RemoteInstall folder and reboot. Once rebooted Install WDS but do not configure it. Then install the PXE role again on the server.
