janfredrik
Site System in DMZ (SUP)
My mission is to set up a site system (MP/DP/SUP) in a DMZ for managing machines. I have successfully installed the MP and DP roles, but the SUP role is not working as expected
What I've tried:
Adding the WSUS role to the server and WID database (Windows Server 2016), no post installation tasks. Install the role from SCCM site server and get error:
  • WSUS Control Manager failed to configure proxy settings on WSUS Server "SERVERNAME". Possible cause: WSUS Server version 3.0 SP2 or above is not installed or cannot be contacted. Solution: Verify that the WSUS Server version 3.0 SP2 or greater is installed. Verify that the IIS ports configured in the site are same as those configured on the WSUS IIS website.You can receive failure because proxy is set but proxy name is not specified or proxy server port is invalid.
  • WSUS Control Manager failed to monitor WSUS Server "SERVERNAME". Possible cause: WSUS Server version 3.0 SP2 or above is not installed or cannot be contacted. Solution: Verify that the WSUS Server version 3.0 SP2 or greater is installed. Verify that the IIS ports configured in the site are same as those configured on the WSUS IIS website.
Adding the WSUS role to the server and WID database (Windows Server 2016), post installation but not configuration wizard. Success message in SCCM logs but SCCM is not controlling the WSUS (I believe) because it it not showing synchronization info or downloading any files to the WSUS folder.
Is there something I am missing here?
EDIT: I think the issue was that the account I used to add the site system role was in my main domain. When I used an account with local admin rights on the DMZ server it started to syncronize as it should.
Edited by janfredrik
