Domain join fails for a single model
Helloy guys,
I'm experiencing a very strange behaviour in SCCM OS deployment... my task sequence seems to work fine for all laptops, desktops, tablets etc. except for one laptop model (Deployment for Lenovo E570 - Win 7 OS).
I assume that there is a driver issue ,but I simply can't solve it.. During the task sequence the join to the domain "fails". The log claims that no adapters are found.
Funny thing is, that during the TS the drivers are installed and after the TS completes, the NIC is present in the device manager. So WTF!?
All other models are working fine... I've removed the complete NIC drivers from the package and re-added them. And I added different driver versions. Even added the driver to the boot-image. No success...
*UPDATE*  I figured out that, after the driver has been installed the adapter is not loaded. When u open a cmd and run ipconfig only the WiFi adapter is present...
HEEELP!!
So you are still missing the driver for the wired NIC. Import the correct one (Win7 x86 or x64 as appropriate) into your driver package and right-click the driver package to update content.
You don't need to update the Boot images, just import the driver.
I guess the problem is solved. Looks like just lost the overview about all the models we have. Instead of E570, L570 has been chosen as the driver package in the TS... :unsure: I will give it another try.. Thanks for your help!
