USMT for swapping machines
On ‎12‎/‎4‎/‎2018 at 8:17 AM, Noqturnal said:
have you had any luck on this? I'm looking to do something similar
Not really helpful to your situation, but I did put something together, and I'll try to explain how I did it.
For planned hardware replacements, created two collections. The first collection (stage1) runs a required deployment of a script that gathers data from the device. This would be typical stuff we embed on the device to describe the department, business unit, and any other data we want tied to the device. The second (stage other?) is an available usmt backup task sequence, meant for the tech delivering the new device.
  1. When it is time to replace schedule the replacement of the device, the analyst will add it to the stage1 collection. It will gather the info, and condense into an XML
  2. The tech building the baremetal install will have an option in the naming script, which will import the data gathered in the XML. At that point, the task sequence will have the old and new PC names.
  3. Towards the tail end of the task sequence, it will send a remote command to another box to create the USMT entry and archive the XML (so other people will not try to build that replacement twice). The task sequence will add the new device to another collection that makes the restore available to run a usmt restore task sequence.
  4. The day before the replacement, a tech can add the doomed computer to the stage2 collection.
  5. When the replacement begins, the tech logs in, starts the backup through the software center and powers down.
  6. Plug in new computer, and do a restore through the software center.
Not a perfect routine, but is linear enough I can tell people what to do. The problems I had in test was the guy doing my testing thought he would be clever and do step 4 while the baremetal install was running. Typical behavior if the entry isn't made, is to make the target the same PC. This doesn't appear to be capable of being manipulated, and after discussion with my peers I suspect this is a security feature against hijacking other users' data.
Ad-hoc machines will likely just need a manual usmt process to an onsite storage, which we do have something for win7 like that but we'll need to overhaul it for 10. For the record I am going to need to edit this later... I haven't mastered this whole "communication" thing yet.
