Marcin
Task sequence not starting
Hi.
I've got some problems with my xp task sequence (done with help from this forum). My client starts, pxe is loading, and after 'windows is starting' there is 'preparing network connections' for a few seconds, and after that client is restarting with 'abortpxe.com' (helps clearing lst pxe advert from collection, and advertising it again, but its all again the same).
I checked smsts log file, and i get:
[TSMESSAGING] AsyncCallback(): WINHTTP_CALLBACK_STATUS_SECURE_FAILURE Encountered
[TSMESSAGING] : dwStatusInformationLength is 4
[TSMESSAGING] : *lpvStatusInformation is 0x18
[TSMESSAGING] : WINHTTP_CALLBACK_STATUS_FLAG_INVALID_CA is set
[TSMESSAGING] : WINHTTP_CALLBACK_STATUS_FLAG_CERT_CN_INVALID is set
[TSMESSAGING] AsyncCallback(): -----------------------------------------------------------------
hr, HRESULT=80072f8f (e:\nts_sms_fre\sms\framework\osdmessaging\libsmsmessaging.cpp,7703)
sending with winhttp failed; 80072f8f
I used info from this site:
http://scug.be/blogs/sccm/archive/2008/10/30/sccm-osd-pxe-issues-in-native-mode.aspx
to configure cert's on sccm and pxe but it does not help..
I'm out of ideas here..
0 answers to this question
