SCCM Setup with Multi Instances of SQL using different static port
SCCM SETUP WITH DIFFERENT SQL PORT
SQL SERVER CONFIGURATION MANAGER:
Make sure all TCP Dynamic Ports are blank
For every IP interface change the "TCP Port" field to your chosen static port
For the "IP All" Interface change the value of the "TCP Port" field to your chosen Static Port
Restart the SQL Engine :
ON SCCM SETUP (CENTRAL SITE, PRIMARY SITE)
Use comma and port number to specified port besides FQDN
Continue with the setup as usual.
You could do the same when setup WSUS Database, SCCM Primary Site Database, ...
Continue monitoring the status of setup progress by clicking on view log button
Edited by Francis Tran
adding setup result graph
