Sccm needs help
I have installed the sccm server
which countered a lot of problems with criticals etc...
anyway in one way or another it wasnt possible to deploy xp SP3 so
we wants to deploy WIN7 x86 version
so I installed SP2 on the sccm server in order to deploy win 7 entreprise edition.
I need some Real support in here :)
I have made some screens , but I know it isn't finished cause it gives errors and like you can notice in the screens
the WDS
WSUS etc isnt installed or scratched during the update(my opinion)
I give the link so you can check the differents screens and hope you can help me further
it's a deadline :P thanks in advance
yeah looks like IIS to me too
http://www.windows-noob.com/forums/index.php?/topic/490-how-can-i-configure-sccm-2007-sp1-in-windows-server-2008/
check that first post...
for PXE:
the server is PXE only? no DHCP?
i have ALWAYS had to do a basic configuration on the WDS Server prior to it operating correctly. I've scripted it these days for our level 2 ops to resolve, the basics are below. bash it into a batch file fix the locations of file and run. It will remove and re-install the components.
remove the PXE role then run the equiv on you PXE (WDS) Server
c:\PXERebuild\rebuild.bat
@echo off
msiexec.exe /x C:\PXERebuild\MicrosoftDeploymentToolkit2010_x64.msi /qb! /norestart
msiexec.exe /x E:\SMS\bin\i386\pxe.msi /qb! /norestart
NET STOP WDSServer
servermanagercmd.exe -remove WDS-Deployment WDS-Transport
net share REMINST /delete
net share SMSPXEIMAGES$ /delete
servermanagercmd.exe -install WDS-Deployment WDS-Transport
wdsutil /initialize-server /Server:%computername% /REMINST:"E:\RemoteInstall"
wdsutil /set-server /architecturediscovery:yes
msiexec.exe /i C:\PXERebuild\MicrosoftDeploymentToolkit2010_x64.msi /qb! /norestart
NET STOP WDSServer
NET START WDSServer
echo :: ----------------------------------------------------------------------------
echo :: PLEASE INSTALL the SCCM PXE ROLE in ConfigMgr Console
pause
trace32.exe E:\SMS\Logs\PXESetup.log
msiexec.exe /i E:\SMS\bin\i386\pxe.msi /qb! /norestart
NET STOP WDSServer
NET START WDSServer
